Looking for some input here! Egr questions! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-27-2012, 07:34 PM Thread Starter
Kyleu890's Avatar
Alright I don't know if this info is posted elsewhere but I did a fair amount of searching and here I am. I have an I think early 04 CCSB 4x4 with 128k on it with an insight. I really want to get rid of the egr but can't because I purchased an extended warranty good till 150k. So I want to do the next best thing. I need the egr to be in the truck to pass a visual inspection for the warranty company. my question is has anyone had bad outcomes with a freeze plug in both ends of the egr with them being welded in? Also If this is done will it still throw any codes if I keep the egr valve plugged in but no gasses running through the cooler? I can't have any codes for the inspector. Also could this method cause any other problems for my truck?
04 ccsb f350 little red rip! Previous truck
05 ccsb f250 currently bone stock no plans to change it.
Kyleu890 is offline
post #2 of 7 Old 03-27-2012, 09:03 PM
still runs's Avatar
ok it wont throw any hard codes meaning you wont have a check engien light but when you run a dtc it may or my not i think when i put my valve back in the soft codes went away but once i pulled the valve they came back... i think you should be ok pluse you on;ly have 22k miles left thats not much so you should be good
arp studs and all new gasgets
blue spring.... its really blue
full egr delete
Bts tranny
coolant bypass and fillters
rotella red elc
cummings 5.9l banjo bolts
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
regulated fuel return
ficm & ecm to php along with my evo to be flashed
and half in my 401k lol
still have my 401k all of it
SYLSOS
still runs is offline
post #3 of 7 Old 03-30-2012, 06:45 PM Thread Starter
Kyleu890's Avatar
Bump
Kyleu890 is offline
post #4 of 7 Old 03-30-2012, 07:05 PM
still runs's Avatar
you wnat the other option drive your truck till you hit the 150k then mod it if anything happens between now and then you have a warranty use it... those are your options take a chance or use your warranty if something happens
full egr delete
Bts tranny
rotella red elc
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
SYLSOS
post #5 of 7 Old 03-30-2012, 07:27 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
With only 22k miles left, the cheapest route would be welding both ends of the cooler. But this requires you to spend a couple of hours under the hood to remove the EGR cooler/weld/re-install. The only cost to you would be some minor/cheap gaskets like turbo oil feed line.
The next cheapest and easiest would be a EGR eliminator spool plug. This will stop the flow of hot gases and possible coolant from entering the intake. This can be done in about 1/2hr. The only down fall to this method is, the up-pipe is not blocked off and if the EGR cooler were to fail, you would get the white smoke out the tail pipe unless you install a EGR cooler blocker plate.
http://item.mobileweb.ebay.com/viewi...d=280716358592
Either one should make the PCM store a "P" code. You would have to check with your state emissions if the service tech would scan the truck for codes of emissions.
Welding the EGR cooler will keep giving you the "P" codes, even if you clear them, they will come back.
Using the EGR eliminator spool plug will allow you to remove the spool plug before emissions testing, clear the EGR "P" codes, install the factory EGR valve, drive around a couple of days, get pass your emissions test, then go back to installing the spool plug.
Either way, it's recommended to leave the EGR valve plugged in electrically, as to not cause motor issues.
Then after your 22k miles are up, you can do a full delete.
Just be careful with the aftermarket warranties, too many horror stories of what they don't cover.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 7 Old 03-30-2012, 10:32 PM Thread Starter
Kyleu890's Avatar
See that's where my company gets me, they cover engine, injectors, tranny and a bunch of other goodies, but I'm trying to prevent the 3000 HG charge if the egr goes. And the engine and heads are only covered if the failure is caused by a covered part. Which the egr and oil cooler are not covered. Unless there is no way they can trace it back to either of those I would like to take some sort of preventative measure to save my wallet. You guys catch what I'm sayin?
Kyleu890 is offline
post #7 of 7 Old 03-30-2012, 10:50 PM
Quoted: 15 Post(s)
I am happy w/ my BPD EGR cooler. Not worried about leaks w/ it. I still do monitor the EOT and ECT split though.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
