Coolant filter instal question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-27-2012, 10:56 AM Thread Starter
JWhelan2787's Avatar
Got my dfuser coolant filter in the mail yesterday. Can't wait until I get the time to install it! I have a couple of quick questions:
Instead if having to deal with a huge mess when I cut the lines, can I just drain a bit of coolant out of the radiator before I start? If so, how much should I drain?
Second, if I can in fact drain some of the coolant, do I replace with straight coolant or should I add an equal mix of coolant and water?
Thanks!
Sent from my Autoguide iPad app
JWhelan2787 is offline
post #2 of 4 Old 03-27-2012, 11:29 AM
supreme oppressor's Avatar
If you use a clean container, you can just put it back in.
2006 F350 6.0 CrewCab Fx4 - Leveled & 35" Nitto's
2002 Subaru WRX
1983 Kawasaki GPz750 with the 810 big bore kit, parked.
supreme oppressor is offline
post #3 of 4 Old 03-27-2012, 12:10 PM Thread Starter
Ok. How much should I drain? 2 gallons?
post #4 of 4 Old 03-27-2012, 12:13 PM
Quoted: 341 Post(s)
Feedback Score: 5 reviews
Yep about two gallons is all you need to drain
Keep in mind when you cut the 3/4" hose to splice in between the engine block and the valve... Not the valve and the firewall
Alot of guys installed them wrong and have to go back and fix it now due to crappy manufacturer directions
Including myself
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
