P/N questions - Ford Powerstroke Diesel Forum
Old 03-26-2012, 07:38 PM
P/N questions
Ok I'm getting ready to order parts but have some questions, P/N 3C3Z-9439-AA, Intake gaskets. Is this a set of two or only one side? P/N's 6C2Z-6K786-AA ($10.13 EA, 2 REQ), 6C3Z-6K786-EA ($10.99) and 6C3Z-6K786-CA ($10.48) are all clamps, which ones do I need? I'm replacing the Blue boots on the turbo and intercooler. P/N 3C3Z-9T517-AG is the Fuel Pressure Spring Kit w/housing, what is the part number for just the spring and gasket? Thanks. Coach
Old 03-26-2012, 09:00 PM
not sure about the boots and clamps
but I'm 90% sure any intake gasket kit from ford is both sides.
The fuel pressure kit comes with a million gaskets including a new cover, blue spring and all o-rings you will ever need
Old 03-26-2012, 10:58 PM
Part number for the spring and orings / gaskets (ie no cover) is 6E7Z-9C165-B
3C3Z-9439-AA is for one intake gasket (99% sure). You can ask Tousley Ford over the phone to be 100% sure since scha0786 is 90% sure that it is both.
Don't know about the clamp part numbers - again a quick phone call to Tousley ......
Old 03-27-2012, 06:19 AM
Thanks for the replies, Are the intake gaskets reusable or should I buy a new set? Boy the price difference between the whole kit and the spring and gasket is not as much as I thought. Thanks again. Coach.
Old 03-27-2012, 11:10 AM
3C3Z-9439-AA is only for 1 intake gasket need (2) from Tousley and I got newtotal they should be around $20 + shipping i just ordered some
Old 03-27-2012, 01:48 PM
buy a new set, they are reusable but why take the risk. Note the little tabs on the install
