Holy Boost!!
Ok so I totally expected to lose some boost after oil cooler, egr delete...etc. Instead I show 32PSI just stepping into WOT where before I showed 27-28PSI tops WOT hammer down for a bit. Should I be worried about the extra boost?
I did a turbo reconditioning while it was out and updated the oil feed/drain tubes. I just don't understand why I'm showing extra boost and most are showing loss. Somebody smarter than me please explain. ![]() ![]() |
Possibly before you cleaned the turbo it was sticking and not allowing the vanes to move to reach more boost.
man, I can't hardly get 25lbs. 32 would be unreal...
Yea I definitely lost boost. You lucky son of a gun..
I'm running a custom tune so I'm sure that's alot of it now that my turbo has been cleaned proper. Quick Tricks Looney!
In the words of my 9 year old daughter..."I KNOW, RIGHT!?!"
28lbs max for head bolts or you may lift the heads
![]() 2 stroker |
What he said anything over 28lbs will possibly lift heads just something to remember...if you have ARPs I think you will be ok.
It's more the back pressure that lifts heads quickly, than actual boost does.
