Leaf Springs
Will 1 Ton spring sets fit my 03 3/4 ton front and rear? Anyone tried this?
thanks TMAG sent from iPhone using Autoguide App |
bump....awwwww comeon someones had to have tried this
pretty sure the only differance is the block and the springs are the same, unless you mean adding overloads? (which some f250s have)
Which I wish I would've know while shopping around, it was hard enough to find a SRW 6 speed extended cab long bed. The front springs might be a little softer too though. However, you can get x-codes for about $220 online.
F350 are the same as F250, like stated above the blocks are the only difference.
F250 are 2.75" F350 are 3.75" Gotta be careful cause there are blocks that are angled and ones that are not, it has to do with your long box, crew cab etc. I think the short wheel base trucks have the angled blocks as opposed to the crew cab long boxes do not have the angled blocks because there is less angle on the drive shaft, I think? |
thanks for the help guys. sorry its taken me so long to get back online. i thought the one ton had heftier springs out back. Is it the axles that make it?
I have f.350 dually leafs on my truck. They bolted right up, only difference was an extra leaf. The back end is noticeably higher and never squats when loaded or with the trailer on. I think it looks nice too with the back end up. My profile pic is with the old leafs.
you want beefier go with airbags and save your back lol
back stronger than wallet. wanting gently used set...
