What gaskets and O-rings do I need?
Hey all,
Im getting ready to have new OEM head gaskets and ARP studs done to my trk. I already put a new oil cooler and egr delete on a few months ago so now its time for the studs and gaskets. Anyways what gaskets do I need to have this job done? I know ford sells a cylinder head gasket set for about $600 and that is per side..! I cant seem to find a kit that includes gaskets for both heads or am I just suppose to buy 2 kits. I would like to see if I can put a kit todether for cheaper but Im not sure of all the O-rings and gaskets I will need. I know I need more then just head gaskets and studs. So if any of you have a chance could you give me a idea of what I will need or maybe you know of a bulletproof kit that includes everything minus the oil cooler and egr delete. Thanks |
There are a bunch of threads on here listing all the parts needed from Tousley Ford.
how about a link to a good one with a complete list? i have been looking for this too and seems like everyone i find somebody says that is adding things to it or they say that theres a few more that they dont have the receipt for is there one that is complete block up gasket/o ring list? ormaybe a kitthat includesall of them?
Ya but they all seem to include doing a egr delete and oil cooler. If Im only doing headgaskets and studs Im thinking I shouldnt need alot of those O-rings and gaskets. Thats the problem im having.. I did find one kit but it included BO headgaskets and I dont want those.
So here is what I know I will need. This will be a cab off stud job..
ARP studs oem head gaskets intake gasket kit injector seals updated stand pipes (4) W300013 bolts (4) W300051 bolts (2) W300012 Orings (2) W302209 Orings (2) W301390 Origns (2) W301386 Orings What am I missing? Am I going to need new rocker box gaskets? What about another turbo kit? I dont know if the turbo will have to be removed or not. ford sells a cylinder head kit ( 5c3z-6079-g ) but I cant find any info on what exactly comes with this kit. Last edited by SharkDiver; 03-26-2012 at 03:31 AM. |
When you buy the oem head gaskets, you get the standpipes and d-plugs and OEM bolts.
When you buy and egr cooler you get all the gaskets to do that job. Oil cooler, you get all the gaskets to do that job. So most of the gaskets are covered right there. You will need valve cover gaskets, injecor seal kits. |
injector seal kit.
$3.97 each Riffraff Diesel: Motorcraft 6.0L Injector O-rings 03-07 This one above does not seem to come with as many gaskets. $8 each 2003-2006 6.0L/4.5L /VT 365 & VT 275 Injector Seal Kit [AP0002] - $8.60 : Commonwealth Diesel Injection Service, , Inc. $60 for 8, $7.50 each 1843682C91 FORD POWERSTROKE 6.0L INJECTOR SEAL KIT F250 F350 QTY 8 | eBay Fuel regulator update $30 Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit - OUT OF STOCK ARP $407 Autoplicity.com. ARP Automotive Racing Products Frd 6l Pwrstrk Dsl Hd Stud Kt - 250-4202 Head Gaskets 20mm $136 Riffraff Diesel: Ford 6.0L Head Gasket 20mm |
Thanks for the links.. Im not doing a egr delete or oil cooler since I already did those a few months ago. Ill add some valve cover gaskets even tho most say you can re-use them.
Tousley Ford Parts Depot
intake gaskets 3c3z-9439-AA $9.74 each injector o-rings 3c3z-9229-AA (8) @ $3.63 each also have head gaskets at tousley for $135 need (2) comes with standpipes i didnt reuse valve cover gaskets but that is up to you. |
ok.
Here is what ill need. 1) 3c3z-6079-g = $438 Cylinder head kit that comes with both gaskets,injector seals and a S load of Orings and other stuff. 2) 3c3z-9439-aa = $11 this is 2 intake gaskets 1) 3c3z-9433 ab = $89 intake kit that use to come with gaskets but now is updated and does not come with gaskets according to Tousley Ford. 4) W300013 = $16 Uppipe bolts 4) W300051 = $30 Y pipe nuts 1) ARP studs 250-4202 = $400 1) 3C3Z-9T514-AG Turbo mount kit = $11 And I think that is it.. Im also ordering a 5" Diamond Eye turbo back exhaust system..
