Oil cooler ?.
How can you tell if the oil cooler is getting clogged? How do you prevent it from happening?
FYI, i did an egr delete about 3 months ago. Last edited by 2004f2501; 03-25-2012 at 08:51 PM. |
Need something to monitor your ect- engine coolant temp and eot- engine oil temp. Also you can flush your system and get a coolant filter
You need a coolant filter
You can order here Performance Machine & MFG. 6.0L Powerstroke Diesel Coolant Filtration System need to put 5-7000mi on before you do a coolant flush then you need to get some gauges like the Edge CTS just install mine today up and running in 2 minutes what a gauge been running the older Edge forr 2 years this will tell you everything you need to know about your truck the main thing is ECT-EOT max 15* i think if you are at 10* your oil cooler is getting plugged for the casting sand and silicate drop out from the Ford Gold junk coolant, it can't take the heat need a CAT EC-1 Rated ELC coolant but you need to flush the system first before adding ELC coolant. With the CTS you can run 8 things at one time. 2 stroker |
Also scan gauge, those are cheaper but not as nice IMO
What happens if you have a 20* delta and don't change the cooler? I have a egr delete, but don't have the money to do the cooler right at this time. I am just wondering what could/will happen if I continue driving it. Sorry, not trying to steal op thread.
Not trying to steal op's thread either but I have a stock 6.0 with insight. I've been monitoring my ect and eot and I have 6-7* deltas but on highway at 70+ it will run 12 degree deltas with ect ranging from 190-192. Any info would be great. But once again not trying to hijack just looking for info.
whats your coolant temperature??? It should be 190* if the thermostat is working properly.. Quote:
You can get a coolant filter set p to help prevent these problems but a normal 6-7 degree delta is fine, if it gets around 10-12 for short periods of time I wouldn't even care about that because it's all relative to what you were doing, on ramp, hills, 80mph, etc.
I was just wondering because on a 250 mile trip my deltas were 11-14 running 70 mph. Plus I just bought my sinister coolant filter kit yesterday.
Sent from my Autoguide iPhone app Last edited by Kyleu890; 03-25-2012 at 12:02 PM. |
look up the oil cooler back flush article.
