What is the best place for my EGT Probe? - Ford Powerstroke Diesel Forum
post #1 of 31 Old 03-24-2012, 06:27 AM Thread Starter
Just did coolant filtration system, 5 inch exhaust no muffler, and EGR Delete. Now we are going to install the EGT Probe and want to know the best play to put it?
Hope someone can answer with some good detail.
mikendmb is offline
post #2 of 31 Old 03-24-2012, 06:31 AM
jesilvas's Avatar
Quoted: 3 Post(s)
In the driver side manifold.
Hang on, let me get a link.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 31 Old 03-24-2012, 06:31 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Best place is driver side manifold right at the bend. Use grease on the drillbit.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #4 of 31 Old 03-24-2012, 06:33 AM
jesilvas's Avatar
Quoted: 3 Post(s)
https://www.dieselmanor.com/diy/PSD3...60gauge-p1.htm
They say don't use grease, some do, some say motor running.
I did it motor off, no grease, worked golden. As long as you drill straight vertical, then it'll all fall down whereas if you drill diagonally, some of the shavings may not come out.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 31 Old 03-24-2012, 06:40 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
You use grease to help collect the bits of metal that go up in the manifold so it doesnt go into the turbo. You never want that kind of stuff going in your turbo no matter if someone hasnt had issues with it or not. If a pice.gets wegged in between one of the blades and the housing there goes your turbo. Who is this "they" that say not to....lmao
WarChild is offline
post #6 of 31 Old 03-24-2012, 06:43 AM Thread Starter
How come driver side over passenger side?
mikendmb is offline
post #7 of 31 Old 03-24-2012, 06:49 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Its hotter.
WarChild is offline
post #8 of 31 Old 03-24-2012, 06:52 AM
howell_jd's Avatar
The location on the driver side is convenient in terms of probe wire length to the gauge and to avoid other places a conduit might rub or catch or melt..I think the passenger side is probably hotter due to a restriction in the passenger side up pipe at the EGR cooler port (but the magnitude couldn't really be that high a difference). The fact that so many have used this site (driver side exhaust manifold) makes comparison among the community consistent and provides a frame of reference to relate during many driving conditions. Another spot used frequently is the post turbo down pipe. Some even put a thermocouple in both locatoins.
I took my exhaust manifold OFF to install the pyrometer adapter.
Jonathan
Jonathan D. Howell
Lieutenant Colonel, U.S. Army
2005 EarthRoamer XV-LT (Ford F550)
"Americans Travelling America"
howell_jd is offline
post #9 of 31 Old 03-24-2012, 07:08 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Taking it off is the best way to do it but not the easiest or fastest. The driver side is hotter though. I have one in both and my driver side is always hotter.
WarChild is offline
post #10 of 31 Old 03-24-2012, 07:20 AM
howell_jd's Avatar
Definitely not fast but easy is sort of subjective. There are just a few bolts but I will acknowledge that several are DIFFICULT. How much hotter is the driver side?
Jonathan
Jonathan D. Howell
