Changing ipr
I'm goin to be replacing my ipr soon and didn't know if there where any tips ? I alredy got the tool for it. I'm gonna try to do it without pulling anything else. Is there any seals I need to replace or just pull the old one out and replace? Thanks guys
Just be careful w/ the heat shield. You need that to protect it from the heat.
Is there any way to check my ipr before I get a new one ? Like if the screens and o rings are good then is my ipr good ?
Best way for us guys without the Ford IDS system is to monitor ICP volts and pressure, ISP desired, and IPR duty cycle (KOEO, low idle, high idle). A scangaugeII can help you do that.
Alright thanks ! Ima go ahead and pull it and just check it out.
Welp got it out looks perfect so back to square one
