Runaway
How can you prevent a runaway from happening or stop one that is happening? Also, can blue smoke be a turbo seal? i've heard a bad turbo seal can cause a runaway.
I believe that the only way to stop one is blocking the air or shutting off the fuel. If the runaway is coming from self supplied fuel (ie oil leaking from the turbo) then you must plug the air inlet
Only way is to cut off the air. If you have oil leaking by the turbo cutting off the fuel wont do anything. It will run off the oil. If your running down the highway best thing to do is put it in neutral and blow the motor. You can try and turn it off but I would dou t that would do anything.
You stop the air.
I think that point has been made - LOL
The statement was made that the ONLY way is to cut off the air. Not entirely true. Drain the oil (fumoto valve) and you can stop it also. Not sayin to do it that way, just being too theoretical I suppose .......... Last edited by bismic; 03-24-2012 at 03:46 AM. |
CO2 fire extinguisher
Bismic I wasnt clairifying anything. I was leaving my own comment. There is no way to drain the oil if your driving the truck.
If equipped with a manual transmission, stall the engine by selecting a high gear and letting out the clutch - with the brake engaged - after ensuring there are no people in the travelled path (usually not a problem when a diesel is in runaway). Obviously an automatic transmission does not have this capabilty.
Mark is right that shutting off the engine will have no effect on either a mechanical or electronic engine as the pressure in the crankcase supplies the engine oil as fuel to the pistons. Yes blue smoke is a sign of oil in the combustion chamber or the exhaust and not a great thing to see. Overfilling the crankcase is more likely than a failed turbo seal as the intercooler could hold a significant quantity of oil before I imagine sufficient oil mist would provide additional fuel. One nice feature of the electronic monitoring from the PCM is that with unanticipated throttle up condition the engine would likely reduce fuel injection and this alone might avoid the runaway (complete speculation to be honest although I have heard of overspeed idle conditions that could indicate such). Jonathan |
If you get a diesel runaway on the road, you won't likely be driving (for long)...you'll have a plume of smoke from the engine bay.
Jonathan |
