CCV Mod, take a look at these: - Ford Powerstroke Diesel Forum
Old 03-22-2012, 08:11 PM
I posted this in the 6.4 forum by accident, so sorry if you've seen it. If not, check it:
Clean Up Your Engine’s Act With Moroso’s Billet Air-Oil Separators - StangTV
Old 03-22-2012, 08:13 PM
The 85495 has 19AN fitting which are 3/4".... OOPS, MAKE THAT 12AN!!!
CCV Mod, take a look at these:-85495.jpg
Old 03-22-2012, 08:23 PM
This will be good to look into if you don't want the oil spewin under the truck. I do think the 3/4" would work with our setup.
Old 03-23-2012, 02:10 AM
I will have to check tat out.
Moroso is about 10min from my house.
Old 03-23-2012, 06:21 AM
12AN is 3/4"........ All AN numbers are the numerator over a constant denominator of 16. Also never seen an odd numbered AN fitting, not saying it couldn't happen.
Old 03-23-2012, 06:23 AM
they exist. namely 3AN.
Old 03-23-2012, 06:56 AM
[facepalm smiley] I knew that
Old 03-23-2012, 07:22 AM
I meant 12AN! duh!
----> Moroso 85495 Moroso Air & Oil Separator Tanks
Old 03-23-2012, 09:00 AM
Suck, Squish, Bang, Blow!
Originally Posted by cook03f250 View Post
For that price, might as well get the CCV kit from NCHornet... $100
http://www.ccvmod.com
http://www.stealth-automotive.com
Old 03-23-2012, 10:30 AM
I was with ya on that until I read this:
"Because of the wide variety of hoses available we are letting each customer select their own hose. You will need 10-16 ft of 5/8" ID hose depending on where you install the canister."
Really? They're going to "let me"? Oh gee, thanks. Now I can go hunt around for some hose and spend some more money. That's kind of BS, IMO. If it's a "kit" it should have everything needed.
