turbo silencer ring - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-22-2012, 05:18 PM Thread Starter
Quoted: 2 Post(s)
turbo silencer ring
Has anyone taken the silencer ring out of their turbo, if so how did you do it. Did the turbo sound ok after removal. Well after most of the week I finally got all new injectors in, new oil cooler and blue spring, two screws stripped in the IPR cover so I have to go to a bigger screw and tap the hole, I hate aluminum after you take the screws out several times the threads start to go.
ronnie32567 is offline
post #2 of 3 Old 03-22-2012, 07:04 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Feedback Score: 3 reviews
It looks like you have an '03, the '03' just pop off. The late '04-'07 need to be machined out. There is really no gain in whistle. The whistle comes from the exhaust side (turbine wheel).
Silencer Ring ?
My II stage 1 doesn't have the ring either, no whistle gain.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 3 Old 03-22-2012, 07:29 PM Thread Starter
Quoted: 2 Post(s)
Thanks, yea its an 03, mine looks like someone took a punch at 3 places right in the groove to brad the ring and turbo housing.
