Are 6.0 cold natured? - Ford Powerstroke Diesel Forum
post #1 of 53 Old 03-22-2012, 09:45 AM Thread Starter
wv_mtns's Avatar
Looking at a 6.0 and the guy said the first couple minutes you start the truck its a little rough then it runs fine? Is this true or is it the ficm or injector problem?
wv_mtns is offline
post #2 of 53 Old 03-22-2012, 09:48 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Not cold natured at all. It might be Sticktion. Itss very common in the 6.0. Hard to say without more info.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 53 Old 03-22-2012, 09:55 AM
Quoted: 5 Post(s)
Be ready to spend some cash on injectors. With known good injectors and FICM these trucks should start and run smooth as silk. If there is any misfire or rough running theres gonna be something wrong. Sorry...
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #4 of 53 Old 03-22-2012, 10:08 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Rough running specially in cold weather is common.
WarChild is offline
post #5 of 53 Old 03-22-2012, 10:19 AM
LNS4x4's Avatar
If it's taking a couple minutes and not seconds I say there is a problem. Even in the coldest conditions.
2005 6.0 PSD XLT SD FX4 CC LB
Engine:
SCT, SRL, Atlas 80, Arp's, Bulletproof Oil cooler w/ Cold weather package, All aluminum radiator, Bulletproof water pump, Sinister Full Delete, 4" Mbrp turbo-back, Banks Techni-Cooler, Banks intake, Edge insight CTS, Diesel site coolant filtration, CCV Mod.
Suspension:
2.5 Icon Leveling kit, 5" Icon rear block, Pure Performance adjustable trackbar, King shocks, PMF 3 link.
LNS4x4 is offline
post #6 of 53 Old 03-22-2012, 10:30 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
He didntt say it takes minuets to start. He said it.runs rough for a few minuets.
WarChild is offline
post #7 of 53 Old 03-22-2012, 10:31 AM Thread Starter
wv_mtns's Avatar
This is what he said to me. " On cold start-up it has a slight miss for the first mile or so above 2,000 rpm. After it runs a min. It's fine."
wv_mtns is offline
post #8 of 53 Old 03-22-2012, 10:35 AM
k.thed's Avatar
Mine is somewhat cold natured I would say. It never has trouble starting, it always fires right up. But for 5-10 minutes of driving, she generally feels kind of stiff. Usually I keep my RPMs below 2,000 until the oil temp hits about 125 degrees. No misses or anything, just cold natured. I think every 6.0L I've been around is that way. I wouldn't view it as a serious problem unless its just struggling to start and chugging hard at an idle.
k.thed is offline
post #9 of 53 Old 03-22-2012, 10:35 AM
RTR stroker's Avatar
mine did that and it was an injector screwing up.
T.J.
- 2004 F250 FX4 crew cab -
* 4" MBRP straight pipe TB 5" tip
* "blue spring" upgrade
* 6.4 banjos
* A pillar triple gauge pod (egt,boost,trans temp)
* 2" leveling kit
* 35" yoko's
* 05' headlights(soon to be front end)
* 08' Taillights
* CCV reroute
* EGR Delete
* Sinister coolant filter
* Riff Raff boots
* Rotella T6
RTR stroker is offline
post #10 of 53 Old 03-22-2012, 10:46 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
All that is contributed to sticktion. Itss probably the most common issue with the 6.0. Find out what type of oil he is running and check for.codes after driving it. T6 and some rev-x or ar9100 should clear it right up.
WarChild is offline
