boost drop off at WOT? - Ford Powerstroke Diesel Forum
Old 03-20-2012, 07:58 PM
so i went out for my bi-weekly "cane on my truck for an hour" drive. and i noticed that at WOT on the flat at around 2800-3000 rpm, my boost starts to drop off from 25 plus to 15ish. is this normal? and on a side note, when i really get on it my scangauge reads boost up to 25, then throws out a negative number i was seeing -10 to -12? wtf is up with that? any help or info is appreciated.
Doug
Old 03-21-2012, 06:37 AM
War is the answer!
Try tightening all you clamps. I would recomendd taking all your boobs off and cleaning them and then tighten them down really good.
Old 03-21-2012, 06:38 AM
Slacker
Feedback Score: 4 reviews
Quoting so you can't change it later...
Freudian slip??? Got something on your mind???
Old 03-21-2012, 06:40 AM
War is the answer!
Damn auto correct....lmao
Old 03-21-2012, 06:41 AM
Slacker
Just messing, man.
Old 03-21-2012, 06:45 AM
Mmmmmm.. Boobs....
War is the answer!
Originally Posted by Evil Eye View Post
Just messing, man.
Everyone loves a good boob cleaning.
Old 03-21-2012, 06:53 AM
You wouldn't be human if you didn't!
Old 03-21-2012, 06:55 AM
I have seen the Scangauge go into negative numbers on boost, but it was only over 25psi of boost. Not sure if the X-gauge isnt right for the truck or what.
As far as the loss of boost could be as simple as a boot(boob) or maybe an intercooler tank leaking under high boost numbers.
Old 03-21-2012, 06:58 AM
Slacker
I have noticed that mine will drop off sometimes as well, but no noticeable decrease in power. It's more evident when I tow my 5th wheel all loaded up, but that could be because I'm running my tow tune. I just figured that the PCM was determining that the VGT didn't need to be running that much boost, opened the vanes a bit and dumped off some boost. Like I said, I didn't notice a decrease in power when it happens.
