coolant flush help! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-20-2012, 01:51 PM Thread Starter
coolant flush help!
hey guys, got a couple of questions before i tackle my cooling system flush. my 07 is running about 10 delta right now at 75 80 mph, much closer around town and idleing. but i know that the time is right to strike or forever regret the inevitable. have a gallon of restore, and a gallon of restore plus, got it from ryder fleet thru my company, very quick service around 27 apiece with shipping. i decided to give the evans coolant a try. i read all the stuff concerning flamablity and the need or not to drill the cap to releive the remaining h2o. still think that it is the most dependable of them all, after all doesnt evans hold the patent on about any and all cooling system coolants. i also have the fumoto valves for the drain plugs. i have enough left over to add the coolant filter, what would all of you guys recommend, and please refresh me about which filter to use and which will not be good. one more question, i plan on flushing the filter on every phase in an effort to save it. think i can. i was going to order the oil cooler cap gasket 3C3Z-9N693-EA which show up as an o ring for about 7 bucks, is this what i am looking for or am i replacing the gasket the two tork screws, hold the cover down with. thanks , this site has been a real savior to those of us fighting the recession.
JMULLENSTAGERIGGER is offline
post #2 of 12 Old 03-20-2012, 06:44 PM
USMC 0311
Mattc0508's Avatar
I think I would hold off in doing your coolant flush until your about ready for a new oil cooler. My reason for that is cause when you do the flush it will loosen up alot of crap in there that is gonna get caught in your oil cooler as a result your deltas are going to grow. So I think I would hold off until you are prepared to do the swap.
Quis custodiet ipsos custodes?
2006 F-250 Lariat CCSB 4x4
18x7 American Eagle 197
285/60/18 Nitto Terra Grapplers
Edge Insight CTS
Black Grille
PMM EGR Delete
Cat Delete
CAT ELC
Blue Spring/Banjo/Zoodad/High Idle/Fog Light Mods
SCT SF3 w/ Looney Tune from Vivian @ QuickTricks
Mattc0508 is offline
post #3 of 12 Old 03-20-2012, 06:55 PM
Galaxie's Avatar
Hit or miss man. Some flip over with a full flush when they have a slight delta and it goes away. Some clog. I had a very small delta and it got a bit smaller with my flush. Clearly my cooler was healty before hand tho.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #4 of 12 Old 03-20-2012, 06:57 PM
USMC 0311
Mattc0508's Avatar
Yea that's true but I don't think I would want to risk it unless I was in a position to do the swap if it started to go south after the flush. Just my $.02
Edge Insight CTS
Black Grille
PMM EGR Delete
Cat Delete
CAT ELC
post #5 of 12 Old 03-20-2012, 07:02 PM
F250SixOH's Avatar
Exactly the same thoughts I have with my truck. My deltas are borderline and I'm not going to do a flush and change to ELC until right before it gets studded. If it ain't broke, don't fix it in this case.
F250SixOH is offline
post #6 of 12 Old 03-21-2012, 05:32 AM Thread Starter
thought of that
guess its a chance you take, i plan on flushing the cooler at every phase of the process also. and hopefully the filter will help keep anything loose that is still flowing out of circulation. i think its worth the chance and if the deltas go up it would only be a matter of time before they would anyway, and if thats the case i plan on bulletproofing the system, because the 6.0 really seems to be a great motor,, just fords misapplication in so far as the proper coolant to use.
post #7 of 12 Old 03-21-2012, 06:49 AM
F250SixOH's Avatar
The filter is only a bypass. It doesn't actually filter out all of the coolant that is running through the system hence most of what is flushed could potentially go straight back to the cooler and catch it. I know some people have had some luck reverse flushing or something like that. Personally if I was going to do the flush, I would have a shop lined up with available dates to bulletproof it.
post #8 of 12 Old 03-21-2012, 09:16 AM
A wise man told this to me and I'll pass it on FWIW:
"If it ain't broke dont fix it; or fix it til it breaks"
pappy42 is offline
post #9 of 12 Old 03-21-2012, 12:44 PM Thread Starter
made my decision
like pappy says, if it ain't broke dont fix it, by flushing the cooler for at least 30 minutes every time i hope to eleminate all of the crap, that ain't allready secured itself to the cooler permenately. i certianly understand that the flush with the two seperate cleaners is meant to lossen the crap and hopefully end up out of the system. i am hoping that the info i have read regarding the complete flush process will at least dislodge and drain to the block drains most of the stuff that might be newly lodged in the cooler, and i do understand that it is a by pass filter, but think it should help, from what i have read. one of the questions i still have is with the oil cooler cap gasket, whether it is indeed an o ring or a regular gasket, hate to find out later, and if it is indeed just a gasket, i have much experience in making my own out of gasket material, o ring another matter, at any rate, thanks for all the input keep it coming, and by the way order a filter kit from PMM today and two replacement filters, only 150 and it shipped today, so what ever seemed to be the problem earlier this month has be taken care of, or at least i will let everyone know if that is indeed not the case, should have it in my hands by monday, tuesday at the very latest
post #10 of 12 Old 03-21-2012, 12:58 PM
War is the answer!
WarChild's Avatar
Quoted: 20 Post(s)
You can always do a reverse flush. Itss a lot safer.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is online now
