Whats the differance ?? - Ford Powerstroke Diesel Forum
Old 03-19-2012, 10:11 AM
So i have a 2004 f250 with a blown motor so i bought an 06 e250 and planning on doing an engine swap. Is there any major differances in the motors that it wont work.
Old 03-19-2012, 10:19 AM
Sorry I have no answer for you, but was just curious how it blew?
Old 03-19-2012, 10:36 AM
Lost compression in two cylinders blown head gaskets and bad hpop
Old 03-19-2012, 11:21 AM
early or late build 04? I know the 03-early 04 had different hpops which werent as good but had the better egr coolers, ICP sensor is in different spot, dont think you should have any problems
Old 03-19-2012, 01:37 PM
I recall seeing some notes in the manuals about parts that are different between the truck and the van... I know the fuel pump/filter assy known as the HFCM (Horizontal Fuel Control Module) is in the van a VFCM so you can't use that, but your truck's is probably fine... isn't there a different oil filter on the van? Meaning a different housing if so...
Basically trying to say I'm not sure what, but there are some differences that you can probably deal with by keeping the truck parts in the cases where it's different.
Old 03-19-2012, 01:44 PM
Feedback Score: 5 reviews
Are you studding the engine w/ ARP's while it is out before putting it in the truck...
I would STRONGLY suggest it...
I din't and now I regret it SOO bad.
Old 03-21-2012, 11:43 PM
yeah iknow it has a remote oil filter and the ecm is detuned on the vans meaning that it isnt turned up to 325hp like the trucks it is more like 225hp but yeah i was planning on studding it and using parts i need to swap off of motor like ecm and oil filter and wiring harness just didnt know if there was anything i was missing that was a major differance and yeah i am studding it before i install
