Is this turbo FUBAR???? - Ford Powerstroke Diesel Forum
Old 03-10-2012, 05:04 PM
I just picked this up for $100. I Just spent some time cleaning it up.(pics taken before cleaning) It has very little shaft play, but a couple of the compressor wheel blades have tiny little chips at the corners, and the turbine housing was very oily. I know the rebuild kit is cheap, but I don't think I can wait. Is it safe to run?
Old 03-10-2012, 05:12 PM
If the fins are like that, I wonder if the guy was overheating the motor.
I'd probably get it balanced out, just in case.
I'd DEF rebuild it for sure.
Old 03-10-2012, 05:24 PM
Looks rough.
Old 03-10-2012, 05:32 PM
Powerstroke Techie
Feedback Score: 3 reviews
I wouldn't run that, looks like oil is leaking out of the turbine seal. The blade is dinged up too which is pretty unusual for the exhaust side
Old 03-10-2012, 05:41 PM
The turbine (exhaust side) is in really bad shape. I wouldn't run it based on that. Coach.
Old 03-10-2012, 05:45 PM
Those aren't bends you see on the turbine wheel. Its grime from my fingers from when I spun it. I'll get another pic up soon.
Old 03-10-2012, 05:46 PM
It's that dirty?
That's terrible.
Old 03-10-2012, 05:47 PM
It almost looks like the VGT actuator over extended the vanes and they hit the wheel.
Old 03-10-2012, 06:04 PM
The turbine wheel is in perfect condition as far as I can tell. Like I said before it was just grime on the edges that made it look bent.
Old 03-10-2012, 06:06 PM
Yeah its pretty dirty. Here's the compressor wheel.
