Another delta question???? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-09-2012, 09:26 PM Thread Starter
Quoted: 101 Post(s)
Feedback Score: 3 reviews
I understand the whole delta process. Get the ECT up to 190 at 65 mph on the flat highway and check out the EOT. It should be under 15 degress. But my question is what role do different gears do to this delta. I have 4.30 gears instead of the 3.73 that came with the truck. Does this cause the EOT to be higher than normal.
I'm just curious. Current ECT 190-194 EOT are 198-200. I think that my deltas are fine right now just my brain spinning.
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #2 of 7 Old 03-09-2012, 10:25 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Basically you want to get on the highway and run under 2000 rpm. Its not your speed but how your engine is working. The test sees if the cooler is cooling.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 7 Old 03-10-2012, 02:27 AM
Quoted: 15 Post(s)
The surrent TSB states to carefully accelerate to WOT to achieve maximum boost for the test. The engine needs to be up to temp also (coolant at 190 or higher).
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #4 of 7 Old 03-10-2012, 04:03 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
That's so your temps get over 190*
WarChild is offline
post #5 of 7 Old 03-10-2012, 09:27 AM Thread Starter
Quoted: 101 Post(s)
So I guess that's what I mean. I always see the 65mph on flat highway, but my RPMs at 65 is different then the RPMs on the truck with stock gears. I guess its not that big of a deal.
post #6 of 7 Old 03-12-2012, 04:58 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
I find overall MPH determines EOT. I'll lower EOT 5*+ if running at 50 MPH compared to 70+ MPH. I would guess RPMs play a part into the temps too.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #7 of 7 Old 03-12-2012, 05:32 PM
cook03f250's Avatar
Interesting... I was running down the highway today at 70 miles an hour and when my EOT got up to 190 my ECT was 187.
That's good, right?
cook03f250 is offline
