A/c turns off, when 4x4 activated!!!! - Ford Powerstroke Diesel Forum
Old 03-09-2012, 06:09 PM
Any ideas? It comes back on as soon as I turn switch back to 2 wheel drive.
Old 03-09-2012, 06:12 PM
Vacuum leak.
You sure the AC actually goes off or just changes from vent to defrost.
Old 03-09-2012, 06:14 PM
Ahhhh!!! Good question..will check it out in morning.
Old 03-10-2012, 05:39 AM
I would think that it is a vacumn issue.
Old 03-10-2012, 05:46 AM
War is the answer!
Thats what Jesilvas said. Can you post your reason you think that so everyone isnt posting i think its a vacume leak.
Old 03-10-2012, 06:03 AM
Feedback Score: 3 reviews
The hubs are vacuum operated, it's common for the vacuum operated hub seals to fail. Since the OP posted that it only has a A/C issue when in 4wd, that is a good inducation of the hub seals are bad.
Old 03-10-2012, 06:10 AM
I engaged 4x4 earlier. The front hubs don't engage unless done manually by turning to manual. Sounds like a vacuum problem.just need to see if fix/repair is cost effective!!
Old 03-10-2012, 06:12 AM
Sorry did not see what jesilvis said. Lilpooh thoughts were what I was thinking with so little info from the OP.
Old 03-10-2012, 06:17 AM
War is the answer!
Yea myAC doesnt turn off but although I hear the transfer case engage my hubs do not unless I put them on manual.
Old 03-10-2012, 06:20 AM
Mine auto hubs haven't worked in 2 years, I'm waiting to fix them when/if I need to replace the ball joints or hub assembly.
