Replacing ball joints - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-09-2012, 06:58 AM Thread Starter
MasterOfTheHat's Avatar
Over the last couple of weeks I've been able to feel some shake in the front end, especially when turning sharp at low speed. I was suspicious it was the ball joints, and when I recently had the tires rotated, the techs confirmed it. So I took it to a local shop to have the ball joints replaced with Moogs, and I got a call this morning that the slack on the right side is the ball joints, but on the left side, it's the hub and ball joints are still in good shape. That make sense to anyone?
Because it was going to be about $850 to replace 2 joints and the hub or about $1300 to replace all 4 joints and the hub, I told him to just replace the 2 joints on the passenger side and the hub on the driver side but leave the stock ball joints on the driver side. Now I'm wondering if that was the right move...
Any thoughts?
2004 F-250 CC Lariat FX4
- high idle mod
- heated mirrors switch
- BFGoodrich Rugged Terrain T/A LT265/75/R16
MasterOfTheHat is offline
post #2 of 12 Old 03-09-2012, 08:11 AM
snopro_03's Avatar
You prabably should have had all four done, he's gunna be half way to the joints with just the hub off. And If one side has failed then the otherside is not far behind. I just did all four of my joints at 70,000 miles. I couldn't beleive how much play my driver side had considering the lower milage, the passenger side had little to no play but i did them anyways.
Chad
2003 6leaker
N.E.W 2.5 Truck
snopro_03 is offline
post #3 of 12 Old 03-09-2012, 08:15 AM
draboo's Avatar
What part is the hub?
I just had all four ball joints replaced. The cost was $1050 including alignment.
If ,while replacing the hub, the ball joints have to be pressed out, you might as well have them replaced instead of installing the old ones back in.
My left side joints had no slop, but I opted replace all four. When one is shot, the other 3 can't be far behind.
2003 F250 Lariat
draboo is offline
post #4 of 12 Old 03-09-2012, 09:42 AM Thread Starter
Yeah, the more I thought about it, the worse I felt about replacing 2 of the 4. Just called and told them to swap all 4 plus the bad hub.
And draboo, I have no clue what the hub is! Anyone care to enlighten the morons amongst us?
- high idle mod
post #5 of 12 Old 03-09-2012, 10:32 AM
Mr. Black's Avatar
Quoted: 5 Post(s)
He's talking about the unit bearing on the left side. It's a sealed wheel bearing assy.
When I had the ball joints done on the early 99 I didn't do them at the same time right vs left. If the joints are still good then run them till they are worn. Then again, I am not independantly wealthy either so I can be a cheapskate that way. Just can't see changing out perfectly good parts.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
Mr. Black is offline
post #6 of 12 Old 03-09-2012, 04:55 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
Just because a ball joint doesn't have any play doesn't mean nothing is wrong with it. if the joint is dried out and starting to rust it'll wear in no time at all. I don't always replace 4 balljoints at once but I usually try and steer customers in that direction. Once one side is worn the other will usually be right behind it.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 12 Old 03-09-2012, 05:39 PM
Glow Plugs Only
dee004's Avatar
Do the new Moog joints have grease fittings? This sealed stuff sucks.
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #8 of 12 Old 03-10-2012, 02:17 PM
mechanix's Avatar
I am the same way, also I would take a hard look at the front axle u-joints too, if you are to the point of replacing the ball joints, u-joints are not much more work to replace. Doing it all at the same time gives you piece of mind too knowing that you wont have to mess with the front end for 80k or so.
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
post #9 of 12 Old 03-10-2012, 02:24 PM
asian195's Avatar
Quoted: 2 Post(s)
I replaced the driver side hub replaced last summer. then 2 weeks later it was back in the garage to do the other side plus ball joints. then a month later i replaced the driver side ball joints. lessened learned, should have just done them all at once in one day. also make sure the ball joints they are putting in have grease fittings.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #10 of 12 Old 03-11-2012, 06:49 AM
Mr. Black's Avatar
Quoted: 5 Post(s)
I went 3.5 years and 30k+ miles between left side and right side ball joint changes.
I understand that this is probably not the norm and is the exception.
Steve
