Transmission Fluid Change? - Ford Powerstroke Diesel Forum
post #1 of 26 Old 03-08-2012, 05:16 PM Thread Starter
I bought my truck with 78,000 miles on the odo, and without looking at the scheduled maintenance log I assumed that the previous owner had gotten the ATF changed every 30,000. I've done all my own maintenance and fluid/filter changes since I bought it, but I can't change what was or wasn't done to it prior to my purchase.
Now, as I have been pouring over the maintenance log, I'm not sure that it's ever been changed (currently I'm around 87,000 - about to be at the 3rd interval). Mechanic tells me if I'm not sure it's been changed yet, I should just see how far I can go without having any issues. The dealership service tech (I wanted a second opinion) told me to change it, it wouldn't hurt anything. I can't take him too seriously though, because he was adamant about me using Gold coolant - even though I didn't ask for his opinion on the matter.
It seems like there's a group of people that recommend just dropping the pan, and filling up the system with 4 or 5 qts. Others seem to think a full out flush would be fine. So now I'm coming to you all to see what you think. I don't like the idea of riding out my transmission till its death, but I also don't want to speed that up by doing something that will hurt it.
As always, thanks for the help.
dhr05b is offline
post #2 of 26 Old 03-08-2012, 08:25 PM
roadapple's Avatar
Just change it!
Cheap insurance and peace of mind.
If you do change it yourself, i recommend pulling the pan to inspect the magnet. And the filter too
roadapple is offline
post #3 of 26 Old 03-08-2012, 08:40 PM
I have done both (dealership did the flush, I did the drain and fill) - either way is fine.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #4 of 26 Old 03-08-2012, 08:47 PM
smokersteve's Avatar
Quoted: 20 Post(s)
Look at my sig.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #5 of 26 Old 03-09-2012, 04:48 AM
howell_jd's Avatar
As a start, get a sample analyzed at a laboratory:
Blackstone Labs
Predictive Maintenance Services, Inc.
Oil Analyzers, Inc. - Oil Analysis, Oil Testing Services
Each of these labs (or an over-the-road truck service center where the analysis will be performed while-you-wait often) provides an objective measurement of contaminants and wear products as well as examination of the viscosity and (in the case of the Blackstone) a comparison to universal averages from other similar components. This analysis will help you to determine if the fluid has been neglected or if the component is in ordinary or out-of-tolerance wear.
Knowing the condition of your used fluids goes a long way to avoiding component failures.
Jonathan
Jonathan D. Howell
Lieutenant Colonel, U.S. Army
2005 EarthRoamer XV-LT (Ford F550)
"Americans Travelling America"
howell_jd is offline
post #6 of 26 Old 03-09-2012, 10:37 AM Thread Starter
Originally Posted by smokersteve View Post
Look at my sig.
Excellent write-up. I really appreciate it.
Everyone else, thanks. I think I'll run a sample first (as howell said) to see if that will steer me one way or another. But thank ya'll very much.
dhr05b is offline
post #7 of 26 Old 03-09-2012, 01:46 PM
Galaxie's Avatar
First flush was done by Ford. I need to do a 2nd change but that will be done by me.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 26 Old 03-09-2012, 04:09 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
At 87k without knowledge if was ever done take it to a trans shop that can do a full flush.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 26 Old 03-13-2012, 02:48 PM
new2deisel's Avatar
Look at my sig.
I was reading your writeup. Did I read correctly that you started the truck and let it idle for 5-10 seconds AFTER you drained and dropped the pan?
new2deisel is offline
post #10 of 26 Old 03-13-2012, 03:00 PM
new2deisel's Avatar
My local Ford dealer said they would do the flush for $199 which includes external filter change. I am sure mine will be slightly higher as I have a Mag-Hytec Pan. Service guy said an extra $175 to change out internal filter. Truck hasn't had a tranny oil change since I put the lager pan on. That was over 50k miles ago. Does this seem fair? Or should I get the flush then change the internal myself and add the extra oil that I will loose?
