Flushing transmission - Ford Powerstroke Diesel Forum
Old 03-07-2012, 12:54 PM
Is there any way to truly flush all the fluids out of your transmission without taking anything apart I've always been told when you change your tranny fluid your really only able to change what's in the pan and the converter holds all the rest so how do they do it at shops
Sent from my DROID2 GLOBAL using AutoGuide.com App
Old 03-07-2012, 12:55 PM
Also what's the best fluids to put back in
Old 03-07-2012, 04:10 PM
Mercon SP and Mercon LV are the approved fluids for the 5R110 Torqshift transmission. A heated flush machine is needed to properly flush the system capacity. A drain and refill will not get the entire system purged as there is an internal thermostat not readily accessible.
Jonathan
Old 03-22-2012, 06:11 PM
USMC 0311
I'm gonna revive this thread cause I've heard there is a way to drain the converter without the machines I'm just not sure how. So if anyone has instructions or a pub on how to do it I would appreciate it.
Old 04-11-2012, 04:10 AM
I was told of a way that you take off the return line from your trans cooler and run the truck til you get air bubbles then stop refill and repeat til you get good clean fluid coming out or something along those lines.
Sent from my DROID2 GLOBAL using AutoGuide.Com Free App
Old 04-11-2012, 06:37 AM
Contact "smokersteve" Or, read his post:
How To Get More Than 8 To 7 Quarts
