03-07 bolt pattern - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-07-2012, 11:06 AM Thread Starter
strokinsd's Avatar
03-07 bolt pattern
Im sure it's been asked but I couldn't find it anywhere I'm trying to find out If my buddy's 06 20s would fit on my 03 thanks a lot guys!
230k on the clock, 6.4 banjo bolts, blue spring mod, sct xcal3 looney wild, diamond eye 5in turbo back exhaust, airaid cai, edge insight cts
strokinsd is offline
post #2 of 8 Old 03-07-2012, 11:08 AM
k.thed's Avatar
They're the same bolt pattern, but the offset on the 05-07's is different than the 99-04. The axles are wider on the 05-07's, so the wheels are shallower to accommodate this.
k.thed is offline
post #3 of 8 Old 03-07-2012, 11:23 AM Thread Starter
strokinsd's Avatar
So the wheels would be farther into the truck? And are we talking like half an in or quite a bit difference
post #4 of 8 Old 03-07-2012, 11:26 AM
k.thed's Avatar
I believe so. In 05 when Ford went to the coil springs in the front and the larger brakes, it changed the width of the front ends. They should fit, alot of guys run the 05-07 wheels on the 99-04's, but they look goofy, IMO. My 04 has the factory 18's and they're much deeper than the newer style 18's and 20's.
k.thed is offline
post #5 of 8 Old 03-07-2012, 12:07 PM Thread Starter
strokinsd's Avatar
Could a person also put spacers in? Yea these 20s are cheap with new tires and he said if I just pay for the tires the rims are free
post #6 of 8 Old 03-07-2012, 12:13 PM Thread Starter
strokinsd's Avatar
For like 100 bucks on eBay can get 1/2 in spacers what are ur thoughts then I suppose would need longer studs?
post #7 of 8 Old 03-07-2012, 12:15 PM
k.thed's Avatar
Seems like the general consensus is to not use spacers if at all possible. It puts alot of strain on your wheel studs and you'll probably end up breaking them off down the road. I'm sure someone else with more know-how will chime in. I've never had any need or desire to use anything different than spec. Might snatch the set up anyways and turn a dime on them? Alot of people would like to have those 20's! Then you could find some that are better suited for your truck.
k.thed is offline
post #8 of 8 Old 03-07-2012, 01:09 PM
agjake11's Avatar
Feedback Score: 3 reviews
2" spacers are what is needed to make them fit properly and not rub the leaf springs.
13 F250 XLT Premium 4x4 PMF/Icon/H&S/Flo-pro/Frontier
13 Suburban LTZ
agjake11 is offline
