Is there a Master list of Normal readings? - Ford Powerstroke Diesel Forum
Old 03-07-2012, 10:32 AM
Post Is there a Master list of Normal readings?
I have found a list of reading like trans temp, coolant, fuel press, egt, boost, and oil temp.
But I am looking for all the other stuff that you can monitor with SCII like VGT duty cycle, ICP pressure, etc......
I have been digging threads for each reading, I would just like a Master list of normal readings if there is one
Thanks
Old 03-07-2012, 11:03 AM
All I can say is get to reading found this for you hope this helps
Recommended readings - Temperature and Pressure - Ford Truck Enthusiasts Forums
Old 03-07-2012, 11:08 AM
Another good thread
6.0L Diesel: ..................Tech Folder.............. - Ford Truck Enthusiasts Forums
Old 03-07-2012, 11:28 AM
I had that first link, The second one is certainly helpful.
I was just hoping someone had a list like in the first link but with the rest of the readings.
Tags
icp pressure, normal readings, temp, vgt duty cycle
