max boost?...33psi? - Ford Powerstroke Diesel Forum
Old 03-06-2012, 06:58 PM
max boost?...33psi?
when i first bought my truck the egr valve was unplugged when i floored it i got 25psi boost not towing. the other day i took the egr valve out and cleaned it and plugged it back in it runs great but when i floored it i hit about 33psi boost and 1000 degree egts not towing.im pretty sure the truck is stock...maye their is some mods im not sure about the previous owner had added but i really dont think so. just wondering if thats right seems a little high to me??
Old 03-06-2012, 07:05 PM
Old 03-06-2012, 07:07 PM
i think it a little high but i have hit about 32psi but my egt's were about 800
Old 03-06-2012, 08:00 PM
Max boost stock is 27psi I believe, Ive got a stud safe tune from Cale at bts, I floored mine in 5th ,best 1:1 with the zf6 ,and I barly broke 30psi on stock boost gauge, I didn't hold it long but gauge wasn't climbing fast so. I hit 40psi once with last 05 truck on the dyno with innovatives xrace.
If anything a clean valve might push open under boost releasing boost, shouldnt add any..
Old 03-06-2012, 08:59 PM
I hate to piggyback on a thread but I'm using the Torque app on my phone and the most boost i've seen out of my truck is 22-23 PSI.
Seems like I may have some cleaning to do on the turbo or is that ok for an 03 cause its a little larger turbo?
Thanks,
Nick
Old 03-07-2012, 11:42 AM
You will typically get a higher boost reading if you put it under a load (like 45 mph in OD) and roll into the throttle without flooring it. It needs a load to make max boost and most tunes back it off a bit under WOT for safety.
Old 03-07-2012, 11:49 AM
Feedback Score: 5 reviews
The Torque ap uses the OBD2 port which shows a slightly lower boost PSI then mech guages...
And 03 turbos are exactly the same size wise from all of the other 03-07 turbos...
They just have a different count of fins inside (less fins) which makes it louder.
I usually see 25-27 PSI when Im in high Rpms
and 30-35 PSI when I do what PGreenSVT is talking about (rolling into the throttle on the highway and not letting it downshift)
Extreme street and SRL
