Stock coil spring rate - Ford Powerstroke Diesel Forum
Old 03-06-2012, 03:51 PM
I have an 06 F-350 that had "C" code spring stock, now i have a 6" fabtech lift. I was wondering if anyone knew or knew how to find the spring rate for the front coils? Just wondering I have searched on here and on the internet and can't seem to find it anywhere. I haven't called Ford yet but I can already imagine what they will say, "well it doesn't say here on the computer what they are so not sure what to tell you". Any ideas?
Thanks
Tyler
Old 03-06-2012, 03:56 PM
Code C is 6000lb front end. Same springs I have. Stiffest you can get from the factory for the F250.
http://www.plowsite.com/archive/index.php/t-57287.html
Old 03-06-2012, 04:13 PM
So I assume these are light F-350 springs, what is the heaviest F-350 coil spring? Also thank you for the response. That is a help but I am really looking for the rate not capacity. My fabtech springs are 410 lb. springs which are 410 lbs. per inch.
Thank you
Old 03-06-2012, 04:25 PM
Stiffest F250/350 front springs I mean. They are meant for the snow plow package. If I had an extra spring laying around I would rate it at school tomorrow and give you a printout.
http://www.fordf150.net/specs/05sd_specs.pdf
Old 03-06-2012, 04:29 PM
Okay thank you that makes sense! I am trying to see how my aftermarket springs compare.
Thanks again
