underboost code - Ford Powerstroke Diesel Forum
Old 03-04-2012, 01:11 PM
underboost code
My Edge is giving an underboost code, I just got everything put back together after doing head studs, egr/oil cooler, cleaned the turbo and I did use a small amount of anti-seige on the unison ring after I cleaned it. I took it for a drive and it is making plenty of boost, I saw 28# at one time. I can reset the code and it comes back as soon as it is started again, any ideas?
Old 03-04-2012, 07:36 PM
War is the answer!
First its not the Edge giving the code it just reads it but If it keeps coming up then you have an issue with your turbo and it needs to come out for inspection. I would make sure all the clamps are securely locked down.
Old 03-05-2012, 05:27 PM
I understand that the edge isn't causing the code, it's just the messenger. Thanks I'll check the clamps.
Old 03-05-2012, 06:02 PM
Glow Plugs Only
I just started yesterday what you finished. Hope it's something simple like a connector or clamp and that you don't have to tear the turbo out again. good luck
