reset - Ford Powerstroke Diesel Forum
Old 03-04-2012, 12:43 PM
reset
Hello guys.
After you replace your E.G.R. valve do you need to clear the code? dealer said it was bad so i replaced it,old one was pretty build up with carbon.
Old 03-04-2012, 01:01 PM
Powerstroke Techie
Feedback Score: 3 reviews
yes, either clear the codes or disconnect your batteries. The EGR valve has a min stop voltage the pcm has to learn so it knows when it's closed. Technically speaking you should reset the keep alive memory but this isn't possible without a higher end scan tool.
