Blue spring or not? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-03-2012, 05:50 PM Thread Starter
coltsfanjmcguire's Avatar
Blue spring or not?
Just added fuel pressure gauge today. Got some results I wasn't expecting. Didn't matter whether I was idling or running at highway speeds it maintained a steady 52 to 54 psi. So do I add the spring upgrade or leave alone? If add then what is everybody seeing on average as a increase? I don't want to go to high.
coltsfanjmcguire is offline
post #2 of 7 Old 03-03-2012, 05:55 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
How was the reading when you went WOT with it? Like jumping out into traffic, or just having fun?
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #3 of 7 Old 03-03-2012, 05:57 PM Thread Starter
That's when it would be on the low side of 52.
post #4 of 7 Old 03-03-2012, 06:03 PM
Quoted: 4 Post(s)
Most are concerned at 45.
post #5 of 7 Old 03-03-2012, 06:16 PM
Quoted: 4 Post(s)
Here is a thread. A tech in this thread mentions 48 being a concern, 45 and below a problem.
GDS FUEL SPRING UPGRADE - Ford Truck Enthusiasts Forums
post #6 of 7 Old 03-03-2012, 07:24 PM
Quoted: 27 Post(s)
A well known injector supplier (Full Force Diesel - Casserly Injectors) recommends being over 50 psig at all times. I found that interestting.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #7 of 7 Old 03-03-2012, 07:41 PM
2003kingranch's Avatar
I'd say blue spring. mine runs 75 at idle. And 65 at wot
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
