Need Lifting and Wheel Help PLZ!!!!!!!
I know this isnt the right spot to post this but, i know this is the area that gets the most action, hoping to get some good advice quick. I have a 2004 F250 6.0 that i wanna lift 4-4.5'' I read numerous threads apon threads about lifts till my eyes explode. There is so many companies out their to go with. From what i read icon, pro comp,skyjacker, and pure performance seem to be some of the best. I know carli and full traction r above them but out of my price range.
Pro comp 4'' lift with fox revservoir shocks around 1450 consist of: Lift Height: 4 InchesFront Lift: Leaf SpringsFront Sway Bar SpacersBump StopsSteering Correction: Pitman ArmRear Lift: Block/U-Bolt Kit w/Add-A-LeafsShocks: Front/Rear 2.0 Fox Reservoir ShocksShock Boots Not Included Cary's 4.5'' lift with bilstein shocks around 1500 consist of:4.5" Front Hangers and Shackles 5" Fabricated Lift Blocks w/ Built in Bump Stop Box Kit w/ Pitman Arm, Track Bar Bracket & Sway Bar Links Rear U-bolt Kit 1" Bump Stop Spacer Kit 4ea Bilstein shocks Icon 4.5'' Hanger System no shocks around 1200 consist of- 4.5" Front Hangers and Shackles - 5" Fabricated Lift Blocks w/ Built in Bump Stop - Box Kit w/ Pitman Arm, Track Bar Bracket & Sway Bar Links- Rear U-bolt Kit - 1" Bump Stop Spacer Kit Icon 4'' Suspension Lift no shocks around 1300 consist of- 4" Front Springs with U-bolts- 4" Cast Lift Blocks w/ Built in Bump Stop- Box Kit w/ Pitman Arm, Track Bar Bracket & Sway Bar Links- 1" Bump Stop Spacers- Rear U-bolt Kit Fabtech 5.5'' Suspension lift with performance shocks around 1300 consist of- Front Box Kit **2000-04** 2 FTS275 Gas & 6.0L Diesel Front Leaf Spring- 3” Block Kit ** 2000-04** U-Bolt Kit **2000-04 ONLY** 2 Performance Front Shocks-2 Performance Rear Shocks Which would you go with????????????? Also will i need a dual steering stabilizer set up for the front? As for wheels i found a set of ''Incubus Recoil 518'' Wheels since i cant get the mkw m26 due to them being discontinued. Have anybody have any experience with these wheels? Do they Pit or Peal fast? Is this a low quality Wheel? I want to get them in a 20x9 or 20x10 Which with is better? I know i need them in a 8x170 bolt pattern with 4.5'' back spacing. Which offset is best? I really dont want them to stick out far a little bit is no biggie but dont want something to happen and they hit the fender. I have spent hrs and countless hrs doing research and i dont know which way to go. Mabey i am thinking to much into it? But i would like some so other members advice. I extremely appreciate any input. Thanks Joe Last edited by shustack; 03-02-2012 at 02:21 PM. |
4" skyjacker. 35x13.50r18 Mickey Thompson MTZ. Dual steering stabilizer. Total of three steering stabilizers. Looks and rides great. IMO. |
not trying to hyjack but polkville, do you know the specs on those wheels? ...how wide and the backspacing.
I would buy whichever lift did NOT require stacking blocks! I run Pro-Comp springs front and rear. Blocks are for building houses.
Having run 365/65/16 (34.5x14.5) Toyos, if your front end is in good shape, you won't need a stabilizer. I had one on for about a month, bent it wheeling one night in '07, NEVER put it back, no problems, even when I had 14.5" tires. If you're going to run 35X12.5s, may as well get the 10s. I'm on a 4.5 back space, back space and off set are two different ways of measuring the SAME thing. So whatever off set it takes to make a 4.5" backspace is where you want to be. |
Btw I would get the 5.5" lift cuz IMO it never hurts to be looking down at everyone else. lol |
Pics are in my profile. The rear lift is 6" springs, I think the front lift was the 3" hangers and add-a-leaf. Didn't like that too well and put a 5 inch spring on the front.
So you had to have 5" of lift to clear 35x14.50?
Yup. If you look close, you will see where the front bumper was pushed forward to gain clearance also. Those Toyos pulled the trim off the right side of the bumper before I moved it out. I'd still be running them if Toyo still made them.
I would have to look for the link but I'm sure I just found them for like 250 a tire the other day. And I believe I found the nitto terra grapplers for 200 a tire
I couldn't find any last March when I needed tires, so I bought the "me too" BFGs.
