gold coolant ratio - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-02-2012, 02:04 PM Thread Starter
gold coolant ratio
Im about to drain and refill the system with the Gold and finish hooking up my coolant filter. I bought three jugs of coolant and was wondering how much of it I'll need and how much distilled water I'll need. I plan on only draining from the radiator so I think there is a small amount of coolant still left in the block? Thanks in advance!
2005 F350 6.0 CCSB
4" 304 Stainless MBRP Turboback w/ Cat Delete
Edge Insight CTS
Rotella T6 5w-40
Sinister Coolant Filter
325/60R18 Dick Cepek F/C Radial II w/ 2" pucks
Stock EGR Cooler 190000 kms
tonto is offline
post #2 of 6 Old 03-02-2012, 02:51 PM
Cooling system holds 7 gal so I would flush it thoroughly with water first an at least use one block drain and remove the lower radiator hose, but if u dnt wanna do that, I think it would b hard to figure out how much is in the block. Plus, u will have most of the crap un the blOck yet
05 F250 FX4 Supercab XLT LB 6.0 Torqshift ESOF, Boss V-Plow, Diamond plate running boards and toolbox, 105gal Diesel Tank 15GPM pump, 130+k Blue Spring Update, Sinister Coolant Filtration Scangauge 2
joe_r_dog is offline
post #3 of 6 Old 03-02-2012, 03:17 PM
jerg_064's Avatar
If you really don't want to do a few distilled water only flushes...Then you should use 50/50 to refill after your drain and just top her off. I think my block still held like 2gal even after draining the drivers side block plug. So probably 3-4 of each and do your own 50/50 mixing so you know it's accurate.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #4 of 6 Old 03-02-2012, 03:33 PM
TOPFUELF250's Avatar
If you are draining your coolant to install the coolant filter, you don't need to. Make sure the truck is sitting level, keep the cap on the degas bottle and you will lose very little coolant. That's how i did it. I wouldn't just drain the radiator and fill it with new coolant. Kind of like adding fresh milk to half a glass of sour milk. Still sour.
TOPFUELF250 is offline
post #5 of 6 Old 03-02-2012, 05:33 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Use concentrate! Not 50/50.
Here is a good read:
6.0 coolant change
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 6 Old 03-02-2012, 08:55 PM Thread Starter
Well I suppose it would be good to do a cleaning as I've had the truck a year and haven't done anything to it yet. Oddly enough that's the thread I have saved on my phone for when I operate tomorrow great writeup!
2005 F350 6.0 CCSB
Edge Insight CTS
Rotella T6 5w-40
tonto is offline
