NCHornet Props
Purchased the NCHornet CCV mod a while back and was getting some oily fumes in the cab. Sent him an email and he bent over backwards to help me out. Turns out it was my fault for not putting the o-ring back on the elbow that comes out of the valve cover. Solid guy and great customer service.
Bought one myself a month or so ago. Couldn't be happier...just thinking about doing something about the tygon tubing I used instead of heater hose. Been looking for a cheaper alternative than the $100 hose that can stand up to oil/fuel.
I looked for similar but couldn't find a reasonably priced alternative. I went with heater hose and will change out every two years.
Anyone have any better ideas? |
Does the NCHornet CCV mod come with a filter? I know it's supposed to be a closed loop system, I'm just curious if it comes with a filter. Thanks!!
Yes it comes with a filter
Great system.....If only I would put in on finally ![]()
i made my own kit at Rural King with heater hose and everything for about $45
even has a drain valve and replaceable filter
Kevins kit is great. I have had mine on the truck for over 200k with no issues
It comes with some fittings, a bracket and the filter. You have to purchase the hose and the hose clamps. Easy to install. Make sure you use a string to measure the hose length that you will need before you buy the hose. It will save you an extra trip to the store.
I went ahead and purchased it yesterday from Stealth-Auto, I just wish the filter was replaceable (I assume it isn't because it doesn't mention that it is). I know they say they have been running theirs for years with no problems, but like any filter, it's going to break down at some point and no longer be as efficient as it once was. Guess I'll find out when I get it. If it's not replaceable and I'm not satisfied over time, I can always get the Racor 6000 later. No biggie.
What exactly did you buy? I looked at their web site, so much stuff. Trying to decide whether to buy one or build one.
