Rear end q's
04 f350 LB CC SW. What rear end do I have. Is it limited slip?
There should be a tag on one of the rear cover bolts that will have that info.
There is also a rear end code on the door tag. For a cheap laugh, two foot it, mine only spun the right rear before I put in a True Track.
Your rear is a Sterling 10.5
The gear ratio and whether or not it has a limited slip will be on a tag held on by the diff cover bolts. The limited slips are about worthless in these trucks, so even if it does have one then it will probably still do a one tire fire burnout instead of both. I know mine does and it has a limited slip factory. |
Yea I knew it was the 10.50 but I was wondering the book says the fluids never need to be changed but when I go around corners slow its popping like the clutches are sticking.
When I bought my truck it was doing the same thing your describing and I changed the fluid and put in two bottles of the Ford limited slip additive and it stopped shuddering. BTW, the truck had 92k on it
Cool, looks like thats what Im doing tomorrow.
About to start working on this old girls rear end. Looks like Im going to be breaking her seal for the first time.
