please check your fuel filters everyone!!! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-01-2012, 12:11 PM Thread Starter
baycountry16's Avatar
I know this has been discussed in length on this forum, but I just wanted to reiterate to check your fuel filters and change them if you have recently purchased a 6.0L. I bought mine about 4 months ago and decided to change today while doing the blue spring upgrade. Below is what they looked liked. Yikes! Also, look at all the junk that was in the primary fuel filter ( last pic).Who knows when the last time they were changed. On top of that, they were the wrong filters ( Napa Proselect ). I replaced with motorcraft. The primary fuel filter was half white, half brown meaning that it was only filtering half the fuel because it was wrong filter. Also, check your fuel pressure. got the CTS FP gauge last week and was idling at 49 psi and 40 at WOT. Now I'm at 70 at idle after blue spring.
Maybe it's just in my head, but truck seems to be running so much smoother and throttle response is better as well.
Thanks to all on here who told me to check filters, so I just wanted to pass along how very important this is to save your injectors!
ID:	34686   Click image for larger version
ID:	34687   Click image for larger version
ID:	34688   Click image for larger version
2006 F-250 King Ranch Crew Cab Long Bed
146,000 miles and counting....
Mods so far....More to come
ARP Head Studs
Custom Diesel EGR Delete
4" MBRP Turbo Back Straight Piped Exhaust
Zerex CAT ELC Coolant
Updated STC Fitting, Turbo Feed and Drain Tube
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
Edge expandable EGT Probe
Edge Fuel Pressure Sensor
SES SS Billet Grille Inserts
Recon Smoked Cab Light Covers
baycountry16 is offline
post #2 of 15 Old 03-01-2012, 12:23 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
All my filters look like that when I change them. Doesn't mean its the wrong filter.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 15 Old 03-01-2012, 12:24 PM
They are bad looking, did you install the HFCM Water Separator Drain Plug Upgrade while you were there.
DTS Articles - HFCM Water Separator Drain Plug Upgrade
Your injectors will like you for it also
I change mine every 10k and they come out looking clean.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 15 Old 03-01-2012, 12:24 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Those do not look like Motorcraft in the first picture. Aren't Motorcrafts Tan colored?
Your truck thanks you for changing those out!
Thanks for taking the time to post your findings!!
I have always changed all the fluids when ever I bought used. Just a good thing to start my own maintenance clock, no matter what the previous owner did.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #5 of 15 Old 03-01-2012, 12:38 PM
Quoted: 4 Post(s)
This is what mine looked like after 11,000 miles. These were the second change. The first ones I took off the truck when I bought it were covered in crud (lower one that is). And yes, it was a little early, but my curiosity got the best of me after knowing what the first ones looked like.
post #6 of 15 Old 03-01-2012, 12:45 PM Thread Starter
The old filters were not motorcraft, they had NAPA pro select written on them. The reason I said they were wrong is that the primary filter did not have the pin hole on the end of the one side with the large opening like the motorcraft have. There is a you tube video somewhere showing the differences between motorcraft and other brands.
I wasn't meaning to say they won't work, I just am happier knowing I have motorcraft in there. That's all
ARP Head Studs
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
post #7 of 15 Old 03-01-2012, 12:48 PM Thread Starter
Btw, did not install new plug because I wasn't able to get a hold of one before doing this today. I had no problems though getting existing one out with Allen wrench. Came right out. I get it for next change though
ARP Head Studs
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
post #8 of 15 Old 03-01-2012, 12:49 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
The others are fine too. Its the oil filters you need to watch out for.
WarChild is offline
post #9 of 15 Old 03-01-2012, 12:58 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The reason why your primary filter was half white/brown was because the outer skin of the filter wasn't separating the water out of the fuel. That outer skin material of the OEM filter is designed to separate the water from the fuel.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 15 Old 03-01-2012, 01:22 PM
Quoted: 4 Post(s)
Yes I did. I had read and seen too many threads where those drain plugs strip at the allen wrench, or someone has stripped the threads going in too tight.
No more worries!
You wont lose much fuel if you get one in before your next change. Actually should drain more often than that any way.
