Diesel Fuel - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-01-2012, 10:58 AM Thread Starter
Tdubalicious's Avatar
Diesel Fuel
I have always wondered this, but I think I know that answer. Do Semi's run the same diesel fuel as our trucks do? I know that off road diesel is a little different than ours, but is Semi diesel fuel different too? Always wondered, but never had the chance to ask. Thanks!
2005 F-250 CC/SB 6.0
SCT Livewire - Looney by Vivian
High Idle Mod
Blue Spring Upgrade
4" MBRP Straight Piped Turbo Back
PMM Coolant Filter
EGR/Cooler delete
Tdubalicious is offline
post #2 of 11 Old 03-01-2012, 11:05 AM
DIVITA21's Avatar
Send a message via AIM to DIVITA21
It's all the same fuel. Off road disel is the same too. It's just dyed red for tax reasons. It's all the same.
JOE DIVITA
8.5 INCH LIFT
4 INCH MAGNA FLOW EXHAUST
SCT X3 WITH ERIC'S TUNES!
EXTREME STREET!
20 X 12 ROCKSTARS ON 37X13.50X20 NITTO GRAPPLERS
EGT AND TRANSMISSION GAUGE PILLARS
MAG TECH DEEP DISH TRANSMISSION PAN
DIVITA21 is offline
post #3 of 11 Old 03-01-2012, 11:09 AM
Term3's Avatar
Quoted: 2 Post(s)
Same thing for off road gasoline (we call it farm fuel here), all the same. Get caught using it "on road" and you'll be paying a heavy duty fine. In our area I believe it's around 2g.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 11 Old 03-01-2012, 11:20 AM Thread Starter
So semi fuel isn't "off road" fuel right? Still green in color or is it red?
High Idle Mod
Blue Spring Upgrade
PMM Coolant Filter
EGR/Cooler delete
post #5 of 11 Old 03-01-2012, 11:21 AM
Same, yes and no, in Arizona has 8 cents more fuel tax.
DieselFord is offline
post #6 of 11 Old 03-01-2012, 11:52 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Same fuel the semi's fuel with. That's why I try to always fuel at truck stops. Higher volume means fresher fuel. If I can't fuel at a truck stop, I try to find the highest volume dealer in my area.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #7 of 11 Old 03-01-2012, 02:34 PM
Term3's Avatar
Quoted: 2 Post(s)
Also the pumps at truck stops put out a lot higher flow, so keep in mind it will foam more and may unexpectedly make a mess down the side of your truck because your filling your tank thru an inch and half pipe not a three to four inch opening like the semi tanks have.
Term3 is offline
post #8 of 11 Old 03-01-2012, 03:27 PM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
I have been told to watch where i get my fuel. so i have been paying 0.20 cents high per gallon i try to stay at trucks stops. do you guys stay away from the little fuel stations or does it really matter?
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
post #9 of 11 Old 03-01-2012, 03:33 PM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
I fill up where it is most convinient.
Not the deadbeat place but not a "high volume" truck stop.
But i Know that semis dont fuel there cuz its a small station...
Never had a problem with fuel
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #10 of 11 Old 03-01-2012, 04:05 PM
TexanLorenz's Avatar
What about Diesel at walmart? I believe it is biodiesel or has a higher percentage of biodiesel but am not sure. It is about 25 cent cheaper, about 3.73 a gal.,around my area but a fella told me because of the biodiesel you get worse fuel mileage. I don't know but would like to see what is best myself?
TexanLorenz is offline
