How To Evacuate All The Power Steering Fluid - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-29-2012, 08:48 PM Thread Starter
managerisk's Avatar
So I need to flush, or GTFO all the power steering fluid from the system.
How would you evacuate? Should I just flip the truck upside down with the reservoir cap off and start shaking it?
By the way, I'd like to offer a big shout out to FORD for using specially formulated ATF for the power steering system. Apparently I missed the memo on that however, now I got a powersteringatfclusterfubar mixture in there.
Why was the truck low on power steering ATF you ask? Well, its because when I was a changing my fuel pressure spring tonight, I was removing the big pipe that runs just in front and above where that housing where the spring sits........Ok, but WTF does that have to do with the power steering, right? Well here's where the story gets good.....when I was pulling that metal pipe off, I dropped it and it landed on the metal part of the high pressure line that goes from the PS booster the the gear box thingy. The other end of that same pipe came to rest on the positive terminal on my battery.....and guess who didn't unhook the battery before going to work? So the net result was the pipe welded to the steering line. When I yanked it off it tore a hole in that line. Not going to lie though, It was pretty cool.
BUT
For the love of god...I cant get anything right on this truck.
Thanks for the help
2003 6.0, SCT TSX tuner, ARP studs, Sinister EGR delete, 4 inch straight pipe, S&B intake, Sinister coolant filter, Amisol bypass filter, Gillette diesel fuel spring.
managerisk is offline
post #2 of 5 Old 02-29-2012, 09:33 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Here are some suggestions:
Ford Super Duty Power Steering Flush | Superdutypsd.com
Draining or FLushing Power Steering FLuid.... HOW ? - Diesel Forum - TheDieselStop.com
Hope these help.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #3 of 5 Old 03-01-2012, 07:22 AM Thread Starter
managerisk's Avatar
These do help kimosabe! Thank You very much.
post #4 of 5 Old 03-01-2012, 09:13 AM
Thank you for posting your story. It makes me happy to know that I'm not the only one random *%#& happens to while wrenching
Good luck with the fix!
Boreal is offline
post #5 of 5 Old 03-01-2012, 09:23 AM
I am that hot
superxcrewfx4's Avatar
I used synthetic transmission fluid in mine, multi purpose by doing that flush method a few times.
1999.5 Ford F-250 Powerstroke
7.3 Powerstroke Diesel
4" Turbo Back MBRP with 6" Tip Straight Piped!
DIY Intake
Isspro Gauges
Diesel Site Coolant Filter
TW 6 Position Chip
2.5 Inch Leveling Kit
305/75/16 Mickey Thompson MTZ's
239k and COUNTING!!!
superxcrewfx4 is offline
