How do I drain Fumoto valve on starter side - Ford Powerstroke Diesel Forum
Old 02-28-2012, 09:40 PM
Hi All,
I have been researching on this site for a while now, but have yet to post. I hope I will be able to help some of you some day as I have received tons of help from this site. My question involves draining the coolant from the engine block on the starter side with the fumoto valve. I had removed the starter to put the fumoto in, and now with it in I cant seem to get the drain hose over the nipple as the fumoto doesn't have much clearance from the starter. Can I just drain the coolant over the starter or is that asking for problems? Or if I reach up to drain the fumoto and I touch the pos. and neg. on the back of the starter on accident with batteries connected will I get a nasty shock?
Old 02-29-2012, 02:32 AM
Originally Posted by KEVDOG337 View Post
Hi All,
It's definetly tight,but I managed to squeeze a hose on it and ran that to a bucket.
Old 02-29-2012, 03:59 AM
I installed a hose on it as well. In fact, both block drain valves have hoses, connected to a tee and finally a short section of hose that goes to the drain bucket.
Old 02-29-2012, 04:57 AM
I had to modify the ground wire in order to get mine to fit and have enough clearance in order to get the tube on the nipple.
Old 02-29-2012, 02:15 PM
Looks like a tug of war with the ground wire to make it fit... If it s the ground wire(negative) there is no issue. The block is a ground (negative) itself. you should be able to put a thin hose on it...
Old 02-29-2012, 03:16 PM
Glow Plugs Only
http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
See page 10 of the attached document.
Old 02-29-2012, 06:16 PM
I purchased a 3/8" I.D. clear hose from the Depot, ran it to the center of the cross member and slid the 5 gal. bucket under it. 15 or 16 times.
D
Old 02-29-2012, 10:27 PM
Thanks for all the advice guys, it really helped reassure me. I ended up just putting on some rubber gloves and reached up there with both hands and was able to get the hose on pretty easily. After draining it a few more times it became very easy. Does the starter have constant power even with the key off, or only when the key is in the ignition? I didn't get any shock at all and I'm pretty sure I had my hands all over the starter posts while I was working the drain tube on the fumoto the first couple times.
Old 02-29-2012, 11:53 PM
It will not shock you....
There is constant power down there on the large red wire.
