EGR delete question - Ford Powerstroke Diesel Forum
Old 02-28-2012, 06:12 PM
EGR delete question
So I just ordered my egr delete and was wanting to know what other parts I need to order for the instal. Gastket,orings turdo drain tube I was told to only do the oil cooler if I am having temp probelms with it and I'm not. Thanks
Old 02-29-2012, 02:25 AM
War is the answer!
You should replace the oil cooler while your in there. Who told you not to and what are your temps?
Old 02-29-2012, 03:05 AM
I wouldn't replace the oil cooler if your temps are good. You need to see what kind of shape it's in before tearing it down though. Wouldn't want to have it torn down that far and not replace it if it needs to be.
Old 02-29-2012, 03:34 AM
War is the answer!
There is alot more that needs to be discussed before anyone can say do or dont. No one can give you an accurate answer until you know your readings.
Old 02-29-2012, 02:38 PM
A dealer told me if all looks good and the oild stays within 10 degrees of the water temp then the oil cooler is doing its job. I also saw a post that said the same thing.
Aslo no one has gave me a good list of items I need to replace any help would be great.
Old 03-01-2012, 11:13 AM
Check post #2 in this thread...
EGR DELETE & OIL COOLER
NYC helps again...
Old 03-01-2012, 11:53 AM
information regurgitator
There is also a handy link in my signature line for the oil cooler/egr delete if you need any more information.
Old 03-06-2012, 03:10 PM
Thanks that was what I was looking for.
