Adding fuel pressure to my Edge Insight CTS - Ford Powerstroke Diesel Forum
Old 02-28-2012, 08:38 AM
What do I need to buy to add fuel pressure to my Edge Insight CTS? I already have the EAS Expandable EGT with Starter Kit for CS and CTS
I know that I will need the
EAS PRESSURE SENSOR
and the EAS Universal Sensor Input
What else do I need?
Old 02-28-2012, 09:24 AM
This may help
Ford Powerstroke 6.0L fuel pressure monitor and low pressure fix. | Toy Hauler Adventures
I went with a fuel pressure gauge on the column that way it will give you 9 things to look at if you have it with the CTS you only get 8 plus it runs $300+ or- I went this way works well just something to think about.
This is what i got for the fuel pressure gauge, it goes into the test port, this is a cool set up gets the sender away from the heat and viberation of the motor.
Page 30: Fuel Supply System
6.0L Fuel Pressure Adapter
Column Pod
1 Gauge Column Pod (AT)
Autometer Fuel Pressure gauge---Bottom Left (This matches my Dash gauges)
Phantom II Gauges
2 stroker
Old 02-28-2012, 10:06 AM
War is the answer!
Might look at getting this as well. Already have the EGT & the Turbo timer (which I highly recommend). I currently have no way to see my fuel pressure.
Old 03-07-2012, 07:08 AM
Is this going to be my cheapest option?
Edge Insight Fuel Pressure Kit
Will it work as well as using this hose from Strictly Diesel? Going this route would cost ~$30 more.
Old 08-28-2012, 07:54 AM
Subbed for ordering tonight.
2 Stroker is that all you needed? The 3 things listed? You didnt happen to do a write up on this did you?
Old 08-28-2012, 08:42 AM
Don't you have an extra input available on your Universal Sensor Input from your turbo timer? If you do all you would need is the pressure sensor. That may be your cheapest route.
Old 08-28-2012, 09:25 AM
War is the answer!
No the edge turbo timer is its own extension of the accessory system.
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 08-28-2012, 09:40 AM
Oh, my bad. I was thinking it plugged into the universal sensor input.
Old 08-28-2012, 03:20 PM
Hey! If you are at mechanically/electrically inclined and don't need a plug and play solution, you can save some money by buying the Edge universal input and running a AEM pressure sensor instead of the Edge pressure sensor. You'll just have to wire it yourself. This is the route I was going to take whenever I do get an Edge.
The Edge universal input allows any 0-5v sensor to be used, and AEM provides the calibration table for their sensors.
Here's a link to the available AEM sensors:
Sensors and Connectors - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
Note the 0-100psi brass sensor is only $62 MSRP.
Then you can use the other output of the Edge and run a pressure sensor maybe for like water pressure!
Tags
edge cts, edge insight cts, fuel pressure
