Fuel Pressure fluctuations - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-28-2012, 05:39 AM Thread Starter
I'm concerned I might have a plugged filter, my fuel pressure will stay at 66 psi coasting but when I am on it, it can dip into the low 50's and even blink into the high 40's. I have installed a blue spring in the regulator.
My suspicion is my filter may have started plugging, I have only 9500 miles on it, BUT a bad batch of fuel can wreak havoc on the filter.
What do Y'all think?
2004 F-250 XLT- FX4 - 4X4, Supercab, 8' bed, BRIGHT RED, Flint Gray Interior, 6.0 Torqshift
Sinister EGR Delete
Rotella ELC
Gutted throttle body
Coolant filter
Stator delete
Blue spring, 6.4 banjos
NChornet CCV mod
Rotella 5W-40 T-6 oil, Motorcraft filters
EDGE CTS monitor
DELTAJOHN is offline
post #2 of 9 Old 02-28-2012, 05:43 AM
MDRhoads360587's Avatar
I'd spend the $50 and start with the filters. It'd be better than waiting it out to see what happens and chance burning up an injector or two.... Just my 2 cents.
2004 F-350 Lariat FX4 CCSB, Lariat, FX4
5% Tint All Around
MBRP 4" Straight Pipe
ARP Head Studs
Ford Gaskets
Sinister EGR Delete
New Oil Cooler
Cat ELC
Sinister Coolant Filter
Blue Spring
SCT Livewire
Shell Rotella T6 Synthetic Oil
Motorcraft Filters
MDRhoads360587 is offline
post #3 of 9 Old 02-28-2012, 05:46 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Ether the filters (which I would do first) or the pump.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #4 of 9 Old 02-28-2012, 05:50 AM
Could be the pump too, but thats $300. I know cuz i just replaced mine. Mine was cutting out at WOT so I did the blue spring mod. Still didnt help. Replaced the fuel pump on the frame rail and WA LA! No more cutting out at WOT!
5% Tint All Around
ARP Head Studs
Ford Gaskets
Sinister EGR Delete
New Oil Cooler
Cat ELC
Blue Spring
SCT Livewire
Motorcraft Filters
post #5 of 9 Old 02-28-2012, 05:55 AM Thread Starter
How many miles did you have on the truck before you started seeing pump failures? And did you buy your pump from Tousley Ford or International?
Sinister EGR Delete
Rotella ELC
Coolant filter
Stator delete
NChornet CCV mod
EDGE CTS monitor
post #6 of 9 Old 02-28-2012, 05:57 AM
well mine has 205,000 but i dont know if it was the original pump. And i just went to the local Autozone to get mine cuz I had to have the truck running. couldnt wait for one to be shipped
5% Tint All Around
ARP Head Studs
Ford Gaskets
Sinister EGR Delete
New Oil Cooler
Cat ELC
Blue Spring
SCT Livewire
Motorcraft Filters
post #7 of 9 Old 02-28-2012, 06:21 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I notice on your other thread, you installed the fuel sensor right to the test port. In your pictures, the sensor looks to be angled down, there could be a chance that you have air trapped in the sensor giving you a jumpy reading.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #8 of 9 Old 02-28-2012, 06:28 AM Thread Starter
Good point about the sensor angle, lil pooh. I can bring it up some, but I am limited by the CAC pipe. But, come to think of it, the way it's situated should force air out better than the sensor being angled up, where air can gather. Hey, I can give it a try, nothing to lose.
Is there another place aside from the test port, where you can tap into fuel pressure?
Sinister EGR Delete
Rotella ELC
Coolant filter
Stator delete
NChornet CCV mod
EDGE CTS monitor
post #9 of 9 Old 02-28-2012, 06:45 AM
Powerstroke Techie
Lilpooh's Avatar
Its not a matter of angle, it's a matter of bleeding out any possible trapped air. You would need to cycle the key to prime the fuel psi, then unscrew the sensor enough to bleed the fitting and sensor of air. Then tighten up the sensor to see if it helped.
This may or may not help, but it's worth a try since its free.
Lilpooh is offline
