Cleaned egr today, have a ? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-25-2012, 01:17 PM Thread Starter
T diesel's Avatar
Quoted: 20 Post(s)
Is any dampness in the manifold acceptable?
I found a little when before I vacuumed the intake.
Am I in trouble?
Delta's are 6 to 8 degrees.
T diesel is offline
post #2 of 11 Old 02-25-2012, 02:58 PM
Am I in trouble?
It should be a dry soot your deltas look good what is the humidity like could play a part in it, i would recheck in a few days.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 11 Old 02-25-2012, 03:52 PM Thread Starter
T diesel's Avatar
Quoted: 20 Post(s)
The valve was dry.
Just dirty.
T diesel is offline
post #4 of 11 Old 02-25-2012, 03:54 PM
Quoted: 7 Post(s)
I assume you aren't noticeably losing any coolant? How about white smoke?
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #5 of 11 Old 02-25-2012, 04:19 PM Thread Starter
T diesel's Avatar
Quoted: 20 Post(s)
Coolant fine.
Absolutely no smoke.
T diesel is offline
post #6 of 11 Old 02-29-2012, 03:06 PM Thread Starter
T diesel's Avatar
Quoted: 20 Post(s)
Had a Sinister coolant filter installed today, had a "combustion leak test" and it failed. Tech said more than likely it's the egr cooler but it may be the head gaskets or both. he recommended an egr delete to begin with. Is there a more definitive test before I break out the big $$$$? I prefer the BPD egr cooler to the delete, but I would like more info on the entire problem. Any Ideas?
Thanks.
T diesel is offline
post #7 of 11 Old 02-29-2012, 04:24 PM
Quoted: 7 Post(s)
I have a hard time believing it is a bad EGR cooler if you aren't losing coolant, it is dry under the EGR valve, and no white smoke.
That being said, it could have just happened I suppose.
I prefer keeping the EGR system. I installed the BPD EGR cooler for reliability purposes and like it very much.
Mark
bismic is offline
post #8 of 11 Old 02-29-2012, 04:40 PM Thread Starter
T diesel's Avatar
Quoted: 20 Post(s)
T diesel is offline
post #9 of 11 Old 03-02-2012, 04:20 PM Thread Starter
T diesel's Avatar
Quoted: 20 Post(s)
Took her to a new dealership today and had a tech hook up his diag. tool and took a long ride. His opinion was "This truck is running awesome" 5 degree delta and great turbo operation. His advice was to keep a close eye on the coolant level and drive the @#$%^ out of it.
NO CHARGE!
Just earned my business.
T diesel is offline
post #10 of 11 Old 03-02-2012, 04:39 PM
I bet it was pill from the ccv, which is normal. Just check again with the nose pointed downhill overnight that would fill it with coolant if the egr took a dump. If it's bad, unplug the egr while driving until u get a new cooler, but I think it's alright. The oem cooler is fine as long as u maintain the coolant and keep an eye on the delta. I use my scangauge2 and it's great. If u are still running gold coolant, put on a coolant filter, run it for 5-10k, change the filter and do a coolant flush with only restore, not vc9 or restore+. then, switch to cat ec1 elc. I should b good 4 a long time.
05 F250 FX4 Supercab XLT LB 6.0 Torqshift ESOF, Boss V-Plow, Diamond plate running boards and toolbox, 105gal Diesel Tank 15GPM pump, 130+k Blue Spring Update, Sinister Coolant Filtration Scangauge 2
joe_r_dog is offline
