TRANS SHIFT FLARE!!! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-24-2012, 01:34 PM Thread Starter
powerstroke64L's Avatar
Angry TRANS SHIFT FLARE!!!
Ok. I've got this crazy shift flare from 3 to 4 at WOT, and it's starting to piss me off. My question is, if i get rid of the Edge tuner and get a SCT with a custom tune, say Gearhead's or Innovative, will that solve the problem? Has anyone used the Edge tuner and switched to the SCT? If so, what kind of differences did you notice? Love switching power levels on the go, but hate the trans shifting. Thanks in advance.
2009 F-250 CCSB Lariat 4X4 6.4 SOLD
2006 F-250 SCSB XLT 4X4 6.0 SOLD
2013 F-250 SCSB Lariat 4X4 6.7
Fuel Krank 20x10, Toyo OC M/T 33",
H&S MM, 5" flo-pro straight pipe, 7" tip, EGR Delete, leveled, Firestone rear air bags, 6K led fogs, 6K led headlights, recon smoked led tail lights, led interior lights
powerstroke64L is offline
post #2 of 10 Old 02-24-2012, 01:35 PM
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Send a message via AIM to MPTonyT
I had it from stock. Since running Matt's tunes... No more. Hope it helps.
2005 Ford F-250 CCSB-Lariat-FX4-SRW
SCT - Tunned By Matt @ GearHead Performance
FICM Tuned by Bill @ Power Hungry Performance
AutoMeter Gauge Kit (Boost, Pyro, & Trans)
Diesel Site Coolant Filtration System
Viper 5901 Remote Start / Alarm
Zoodad mod w/ Stealth Screen
4" MBRP Exhaust
MECP Master Mobile Audio/Video/Security Installer/ ASE A6 Certified
MPTonyT is offline
post #3 of 10 Old 02-24-2012, 01:51 PM
Quoted: 356 Post(s)
Feedback Score: 5 reviews
hopefully that helps you man.'
That is the reason people with 6.0s DO NOT reccomend anything but SCT. Not saying anything to you, but in general.
Other tuners kill the tranny so if you dont see any different results do not be mad at SCT.
They are made to keep the tranny from dying, not bring it back from the dead!
If that happens... fix the tranny and run ONLY SCT and that will prevent future problems.
Plus a broken tranny is only an excuse to put a better/ built one in
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 10 Old 02-24-2012, 02:04 PM
pizza pig's Avatar
You're getting a flare on the direct (3-5) shift not the 3-4 the trans never shifts 3-4. If yours is flaring replace the direct clutch solenoid, its weak. The Evolution tunes the transmission, but i would still recommend a custom tuned sct.
pizza pig is offline
post #5 of 10 Old 02-24-2012, 02:05 PM
steelnc's Avatar
Had the 3-5 shift flare with another custom tune. Was fine at first, then after a month it started. I got the Srl extreme+ from Matt and asked him to beef up the 3-5 shift. So far so good.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
post #6 of 10 Old 02-24-2012, 05:25 PM Thread Starter
Could you explain some more? I feel it physically shift from 1 to 2 to 3 to 4 to5 and then tc lockup. That's 5 shifts. How does it never shift 3 to 4?
post #7 of 10 Old 02-24-2012, 05:45 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
because the torqshift has 6 forward gears. 3 and 4 are so numerically close it's not practical to shift from one to the other
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 10 Old 02-24-2012, 06:09 PM Thread Starter
Ok. That makes sense. Thanks for clearing that up.
post #9 of 10 Old 02-24-2012, 07:54 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here is more trans info.
http://atsg.com/dyndata/articles/pdf...0Torqshift.pdf
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 10 Old 02-24-2012, 10:44 PM
jeffa6980's Avatar
You could also get a direct drive solenoid from doug and that would solve the shift flare also. just google gogo direct drive solenoid and he should come up. its cheap and a very easy upgrade.
jeffa6980 is offline
