Old style oil drain on a 07 turbo - Ford Powerstroke Diesel Forum
Old 02-23-2012, 07:31 AM
Just had my Egr delete done and my 07 had the old style drain line on the turbo.anyone else come across this... Ask the work prior to my purchase was done at the dealer...............
Sent from my MB865 using AutoGuide.com App
Old 02-23-2012, 04:26 PM
Bump
Old 02-23-2012, 05:39 PM
Powerstroke Techie
Feedback Score: 3 reviews
pics of the drain? There's atleast 4 different drains out there and the latest drain you can buy now was not installed on any F series trucks.
here is the drain that came off my truck and the lastest one available
Old 02-24-2012, 04:09 PM
I don't have pics or the part... He said it was the one that came from 03-04.5 6.0's.... All I know is the dealer did all of the work to the truck prior to Tuesday....and the Egr system had been apart and cleaned twice by them so Idk.........
Old 02-24-2012, 05:47 PM
I dont see the deal with tis upgrade. Mine with 86k was spotless inside. I guess if you change your oil when you should you wont have a problem with it.
Old 02-24-2012, 08:14 PM
Glow Plugs Only
Ford re-designed the oil drain tube with less restriction to the flow of oil to allow for increased oil flow through the turbo.
Old 02-24-2012, 08:26 PM
War is the answer!
It doesnt have to do with oil changes. Its more oil crystalisation from the oil being in the turbo while its hot still. This is why you should not turn off your truck before the exhuast temps reach 350*.
