need help, coolant on front of engine and degas bottle
Ok need a little help here guys. I am getting coolant on the front of my engine, it's hitting the belt and being slung everywhere so I can't really see where it's leaking from. It doesn't leak till it gets warmed up and continues to drip and leak after I shut it off for a little while. I am also getting coolant out the degas cap bottle and I already replaced the cap. The weird thing is the coolant level is still a little high in the bottle so I cannot really add fluid but the upper radiator hose is empty. Truck runs perfect, it has a 155k miles on it and I bought it about 8 months ago. I bought a scangauge for it a couple months ago and thats when i saw that the oil cooler was shot as I had pretty high deltas. So I've recently done a full coolant flush, oil cooler replacement, egr delete, thermostat, coolant filter and cat1 coolant. Also I noticed when I did the egr delete that someone in the past had already welded over the egr cooler so it was non functioning. Truck runs great, little stiction in the morning but pulls hard, absolutely no smoke ever. Could my water pump be clogged or shot? Is the only way for my degas bottle to lose fluid is because of headgaskets? Thanks guys!
What are your temps like when you're driving? Normally, I think people would say ERG cooler but since yours is deleted...???
Is the coolant in the bottle clean? Or does it look like it's got oil in it? |
temps when warmed up, ect 188-192 eot 190-195, coolant looks brand new, translucent red like it came out of the bottle.
bump anyone?
This is an interesting situation. I would be led to believe it's your water pump, especially by the way you described the coolant being flung aground by the belt. But, I do not know why you would have any puking, unless it is just overfilled.
what I don't understand is why the upper radiator hose is empty though. Is it possible the water pump clogged up from when I did the coolant flush? Is it possible for the water pump to overpressurize the degas bottle if it's clogged somewhere?
What level do you keep your coolant? Hot full is the minimum line on the bottle, or if your truck has the sticker, only fill to the minimum line (of the sticker) at cold.
Since you were working on the motor recently, you might have cracked the return line, the little hose going to degas from radiator. Where it connects. Have seen folks crack that nipple. |
well I do have the updated label on the bottle and it was slightly overfilled but that would only explain coolant coming out of the cap and the level is still high in the bottle even though I know it's low on coolant. I don't think that line is cracked as I haven't seen any leaks there.
Wish I had some other suggestions...Maybe someone else can help out??
Can you wash out the engine bay and run it with the hood open and try to see where it's coming from??
I've tried that a little, guess I can try it again, I've gotten under the truck when it's running and warm and can't see a thing. As soon as I shut it off I start getting coolant running down the crank pulley and other stuff, it's dripping off tie rod ends as well. frustrating, because I thought everything was fixed and it's running great.
