Batttery Indicator Light on dash??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-22-2012, 03:54 AM Thread Starter
Pathfinder22's Avatar
Quoted: 2 Post(s)
Garage
The battery light is coming on and going off everytime I drive. Truck starts like a champ and runs as good as every. Both batteries are new and are hi-end/heavy duty Exides.
This started happening about a week ago.
Any thoughts or suggestions??
'06 F350 Lariat CC DRW 6.0L PSD
fully Bullet-Proof'd incl Sinister Diesel Coolant Filtration System, Train Horn, Killer Audio w/ back-up cam & 10" sub and Re-upholstered seats w/ custom canvas covers...240k plus and running strong!!
Pathfinder22 is offline
post #2 of 4 Old 02-22-2012, 06:43 AM
Alternator might not be charging them to the best it can. go get your alternator checked at Advance or someplace like that, you don't even have to take it off, but the bench test is more accurate.
08 F350 CCSB Lariat - massaged exhaust, MiniMaxx, AFE Stage 2, Flo-Pro CAC pipe, CCV modded 2" leveling kit. soon to come - EGR delete, sinister intake elbow
Traded in 06 F350 CCLB - 5" diamond eye exhaust, sct (removed before selling), coolant filter, high idle
Zeek is offline
post #3 of 4 Old 02-22-2012, 08:43 AM
I had the same problem on my truck, it would come on and off never stay on, most likely your alternator, if you have a multi meter you can check the voltage to see if it drops when the light is on. I had mine replaced and so far so good no lights.
2006 Ford F350 Dually
gonecampin is offline
post #4 of 4 Old 02-22-2012, 05:32 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
It's the voltage regulator which is in the alternator. Replace the alternator with a Motorcraft. Don't get any other kind, unless it is a high end alternator. I just went through this and went to autozone for a new alternator. The 3rd alternator finally worked, but I'm waiting to see when this one will crap out.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
