Coolant Smell...
ok, so i've been noticing a faint coolant smell when i walk around the front of my truck. Its not a very strong smell but i smell coolant for sure. I don't smell it inside the truck and i'm not seeing any white smoke out the tailpipe.
I do want to pull the EGR valve and clean that good so that will be a good time to check the EGR cooler out. Any ideas on what to look for before I pull the EGR valve? truck is a 2007 6.0 totally stock except for a edge insight CTs |
check for moisture on front of engine, my 02 6.0 would leak out of the bottom of the water pump only after I shut engine off, would not leak while engine running, it did this for several thousand miles before finnally spewing, sometime just a very little would leak and somtime maybe a pint or so.
This may help
DTS Articles - 6.0L EGR Valve Cleaning DTS Articles - EGR Servicing These guys will show you how to pull it, little raw 6.0L power stroke egr repair - YouTube 2 stroker |
Another thing to check is your radiator. Specifically the areas where your plastic tanks (top and bottom) meet the aluminum fins in the center. Mine seeped from there quite a bit. It's a fairly common problem with these trucks. The good news is that the radiator is fairly easy to replace. Hope this helps!
yea, I forgot about the radiator, at about 160,000 the whole bottom of mine blew out.
i'm going to try to pullt the EGR valve tomorrow but i think i'm fine there. i don't have any steam or white smoke coming from the tailpipe at all. |
Have you done a flush recently? If so you may have just have some residue that gets heated up and stinks alittle. Just a thought.
