New to me 07 6.0L, need some advice - Ford Powerstroke Diesel Forum
post #1 of 33 Old 02-21-2012, 05:48 PM Thread Starter
Leroy88's Avatar
Hi guys, I recently bought an 07 f250 cc sb 2wd, lariat, grey/grey. It has only 43k miles on it, and Im the fourth owner. I read the thread "Every 6.0 owner should know this" or something like that, and I feel much better about owning this truck now.
I picked up Motorcraft oil, and a motorcraft filter, and am locating some Cat EC1 coolant. Where do I get the Restore/restore + and is it absolutely necessary to use it when flushing the ford coolant out?
Ive done the zoodad mod, and made a little screen to cover the hole to keep bugs out, which was a big deal on my 02 7.3L truck. Are there any mods, that are cheap, and easy for the driveway mechanic that can help the truck with mpg? Im averaging 16.7mpg/city and 20-22mpg hwy running 70-65mph.
I read something about a coolant filter system. Is it necessary if i switch over to the Cat ec1 coolant? If so, where can I get it at?
Im pretty sure with the truck having low miles, there arent any issues with the EGR or the oil cooler being clogged.
Is there any suggestions anyone can make to help me make sure the truck lasts me lets say, 15 years? I don't need a programmer with a race tune, I have a race car. The truck is 2wd, so it wont see off road play. Its mostly a daily driver, and on occassion a tow pig.
Thanks.
I am a machinist for the New Orleans Sewerage and Water Board. Ive been an inside machinist for 5 years now, and a 1st class one for 2 of those years. We have the tools to check threads, like I said, Im lazy.
07' F250 CC SB 2wd 43k miles
--RIP--
02' CC SB 2wd 225k miles
94' 5.0 GT 135k miles
Leroy88 is offline
post #2 of 33 Old 02-21-2012, 06:00 PM
Get gauges. Very important in a 6.0. The coolant filter I have I got it from sinister diesel.
ms2004F-250 is offline
post #3 of 33 Old 02-21-2012, 06:02 PM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
I suggest getting the coolant filter from PMM.
Their kit does not require cutting of the factory hoses.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 33 Old 02-21-2012, 06:33 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Just because it's got low mileage, doesn't mean that the oil cooler is OK. Your playing Russian Roulette!!
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 33 Old 02-21-2012, 06:40 PM
2003kingranch's Avatar
except you die every time
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #6 of 33 Old 02-21-2012, 06:42 PM Thread Starter
Leroy88's Avatar
Is there a way to see if the cooler is clogged without a scan gauge? How easy is it to remove, and possibly flush it out?
--RIP--
Leroy88 is offline
post #7 of 33 Old 02-21-2012, 06:46 PM
Powerstroke Techie
Lilpooh's Avatar
Nope, your gonna need a monitor solution. The oil cooler sits in the middle of the engine valley under your oil filter.
Nobody has had great success with removing the old one and flushing till unclogged, the passages are very small, and if your gonna go thru the trouble of removing the old, you might as well spend for a new cooler.
Lilpooh is offline
post #8 of 33 Old 02-21-2012, 06:52 PM
Strokeittothemax's Avatar
oooo i like the look of this one, looks built better...
~Ryan~
Present: 2002 F350 XLT CCLB Dually 7.3L, TS-6pos, 4" Exhaust
2013 Ford Focus ST Black
Past: 2012 CCSB 3500 Cummins (Dads now)
2007 Crew Cab Short Box F250 Lariat 6.0L
2004 CCSB LB7 Duramax EFI Live
Strokeittothemax is offline
post #9 of 33 Old 02-21-2012, 06:57 PM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
I love the edge insight cts units they are a bit highter than the scanguages
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
post #10 of 33 Old 02-22-2012, 03:40 AM Thread Starter
Leroy88's Avatar
Ordered that coolant filter kit from PMM. It looked the nicest, and it was on sale for $125 with free shipping with UPS ground.
So I read another thread and a guy on there is using the Torque app to monitor his truck with a bluetooth obd connector. Im going to see about getting one of those connectors and download the app on my droid to see the oil temperature.
As far as gauges for monitor go, I do want the pyro gauge for EGT, the factory cluster has a boost gauge, and I dont forsee the engines turbo making more than 25psi now, that gauge is good enough.
So that leaves trans temp, and pyro gauges. Since the pods usually come in 3's, is there another gauge I should look into buying?
--RIP--
Leroy88 is offline
