Remove cab to do head studs. Really?????
I am planning some work on my 03 stock 6.0. I am thinking I will "bulletproof" it including installing some ARP head studs. Is it true that you have to remove the cab to do this? I would like to do this work myself but not sure if I want to remove the cab.
no, you dont have to. good luck with the work. if and when you need help, come see us at the .org!!!
You do not have to remove the cab, but it makes it a lot easier. Good Luck
There are plenty of write ups on this site that take you step by step through the process of doing it yourself, a couple of them even have a list of part numbers. Depending how much you buy ahead of time and how much you actually plan on doing (just about everyone will recommend you do a full coolant flush and put in new oil/egr coolers) it shouldn't take too long, some guys have their trucks apart for weeks or even months, but it can (and I use that word loosely) be done in a weekend (with an extra pair of hands, extra pair of heads from the machine shop, and every possible o-ring and gasket you will need for the job). The work itself isn't hard, just a matter of a lot of work on your stomach and some rather heavy components (heads are a hernia waiting to happen if you're not careful) then torquing bolts with limited space. Definitely a learning experience though, and a good amount of fun if you like tinkerin', except for some diesel specific components, it's an emissions controlled pushrod V8.
you act like its a big deal, i pulled my cab in an hour and a half with BS breaks in between. believe me its MUCH easier working on these trucks with the cab off, that is depending on what youre doing.
If mine comes off again, my uncle has a lift at his house... its never in use either!!!
Thanks for all of the replies guys. It does seem like a big deal to remove the cab but maybe not. I plan on tearing down one weekend, gettin the head done during the week and have it back running by the next weekend. I have another truck so no biggy.
If I had a lift I would probably remove the cab when I tackle mine in the coming weeks, but I don't so I won't. I'm quite confident after reading all the very informative posts on the ORG that it really isn't a big deal. All the Techs doing it for a living have all the fancy toys we don't, and most of us aren't overly pressed for time as they are. The following post by Fishermedic is a testament to the fact that it can be done by anyone who has the brass and wants to give it a go
Paramedic Saves 6.0L |
I did mine in cab, in 4 actual working days, and I was down one day waiting for parts.
I have no special tools, just a topside creeper and an engine hoist I really shouldn't have the Autoguide iPhone app, but I do |
