Is it Cheaper to get "Ford" or "International" parts
Just wondering is it cheaper to buy ford name replacement parts from tousley or get International name replacement parts from somewhere. (Need to know where the best place that would be) I have the international numbers for pretty much all the parts i need... Im replacing cracked heads on a early 03 6.0
Heres whats in my shopping cart at tousley ford 3C3Z 9229 AA Injector O-Ring Kit 3C3Z 6A642 AA Oil Cooler Kit (Entire Assembly with Cover) 3C3Z 6584 AA Valve Cover Gaskets qty 2 3C3Z 9439 AA Intake Manifold Gasket qty 2 6C3Z 9448 A Exhaust Manifold Gasket qty 2 3C3Z 9T517 AG "BLUE SPRING" Fuel Pressure Regulator W302472 (Ford Hardware PN) 6.4 Banjo Bolts qty 2 W303659 (Ford Hardware PN) 6.4 Banjo Washers qty 4 6C3Z 9T515 A Updated Turbo Drain 3C3Z 9T516 A Updated Turbo Feed 3C3Z-9T514-AD turbo mounting hardware 4C4Z-9V424-AA turbo reconditioning kit If you notice I'm missing anything let me know as well. will also be getting egr delete, arp studs, and oem headgasket kit from somewhere else... |
You'll just have to price them. Sometimes Ford is much cheaper than IH sometimes it's the other way around. Turbo oil pipes are one example.
Alright. I just wanted to make sure before I put my order in. Sounds like ill just go ahead and go through ford. Not sure it'll be worth all the extra work searchin for everything just to save a couple bucks
Sent from my DROID using Tapatalk |
Yea, it really just depends what exactly you are buying. There is not a good answer for you here. May want to examine options on both.
it depends completely on what you are buying. tousley works good because it's a one stop shop.
One thing you want to get through international is the ICP connector. Don't get one from ford |
