4x4 not working..?
Well I was out hunting this weekend and went to use my four wheel drive and it did not work. I turned the switch to 4 high and the front wheels did not engage. I had to LOCK the front hubs in instead of having them in AUTO to get the four wheel drive to work. Is there a vacuum that engages the hubs in AUTO, where do I need to start checking? Thank you.
Will |
On the passenger side of the engine bay there is a vacuum solenoid. Turn your key to on and make sure the pump runs first. Then use a vacuum gauge and connect it after the solenoid to see if the solenoid works correctly when switching to 4x4. You can also check the lines to the hubs with a vacuum pump to see if one of the seals in the hubs are leaking. The vacuum solenoid tuned out to be the culprit on my truck.
on the passenger fender wheel well? What else does the vacuum solenoid operate? Thanks,
Will |
would like to know the answer to that as well!! Coach
Doesnt that work the AC valve on the radiator hose too?
It controls your defroster or something like that if I remember right. If you switch to 4x4 and the only thing that blows air out is the defroster, you have a vacuum issue. Also can happen all the time if you had a leak before the solenoid I guess.
If your heater will only blow on defrost then you have a vacuum leak. Most of the time it's on the tubing going to the hubs. There are stainless steel braided ones you can buy but I don't recall who sells them. I just remember its a popular supplier.
